A highlight video for this release is available : WATCH HERE
The release is available... HERE on GitHub
This version has been built with Visual Studio 2026 and includes a vc145 c++/c redistribution from Microsoft. It may require you to shut down apps and/or reboot when you install this version.
IMPORTANT NOTE: please follow the steps below for this version
- Take backup of your DB before you uninstall the old version of Thetis, use DB manager to do this
- Un-install the previous Thetis install(s) using Add/Remove Programs. Uninstalling via Add/Remove Programs will leave your database intact
- Remove your wdspWisdom00 file from %appdata%\OpenHPSDR\Thetis-x64
- Install this new version, and reboot, even if not requsted to do so
- Restart this new version and wait for wisdom to be regenerated. This could take upwards of 5 mins, follow the on screen instructions
If you encounter any issues, please report them on GitHub here.
Join our Discord community for test builds and more: Click Here
Cheers, Richie. - MW0LGE
v2.10.3.12 - Change Log
Additions
- [add] you can pick a directx device using -adaptor:# from the command line. Use Thetis.exe -help for more information
- [add] ability to load rnnoise model binary files added
- [add] added functionality to reposition 'lost' forms. This can be found in Setup->[Test->Reposition Forms]. Select the forms you want to move back to the primary monitor starting at 100, 100. The Z order of windows will not be changed so they may appear behind a window on the primary monitor
- [add] you can now hold CTRL+ALT+SHIFT when starting Thetis to show a message to allow you to reset the locations of Thetis console and Setup if they become lost. You can then use Setup->Tests->[Reposition Forms] for any others missing
- [add] %nr% and %rxn% added as script variables. %nr% returns NR number enabled 0-4, and %rxn% returns receiver number used by the container
- [add] it is now possible to use the condition of a led indicator to show/hide text overlay
- [add] new meter item, OtherButtons. Some buttons have icons associated with them. Also button style 13 uses active indicator colour for the text/icon colour. New [fix] option that ignores button size, and uses Scale instead. You can use ALT click drag to move buttons around, let go of click to drop them. SHIFT+ALT will swap two.
- [add] OtherButton items now has macro buttons. You can show/hide containers, send MMIO strings, run cat commands.
- [add] right clicking an OtherButton will show related setup if one exists
- [add] more legacy items can be hidden
- [add] it is now possible to save, load and duplicate containers. At the moment for various technical reasons it is a single container at a time. Note: items such as Led Indicator, WebImage will have their 4char(s) changed to prevent conflict if you were to re-import where they already exist. Meters that use %variables will also not display correctly if those variables are not present. You will have to edit them by hand. A warning is shown if a container being imported has a web image
- [add] variable picker for text overlay and led indicator items
- [add] it is now possible to set ID's for each receiver for N1MM waterfall data, in the network setup tab. This allows for two+ instances of Thetis (SO2R etc) to output data to N1MM
- [add] startup log can be shown. Option in Setup->Test
- [add] VAC and portAudio will now successfully use input devices that report only single input channels. Previously input required a device that reported two channels and would fail with certain USB headsets and USB dongles such as the Syba SD-CM-UAUD USB
- [add] option added in tci setup to force a CW spot to a specific sideband. See tooltips for more info
- [add] WDSP 1.27 post processing noise functionality added to NR2. Settings in Setup->DSP->NR/ANF
- [add] WDSP 1.29 adds 3 new CW APF types to the original Bi-Quad. These new types are Double Pole, Matched and Gaussian. A new button to cycle through them on the main CW ui panel has been added, setup options, cat command ZZAYn; where n=0 to 3, and 4 new midi command buttons to select each. Note: the button may not be part of your skin pack. The new button requires images btnAPF_type-0.png and btnAPF_type-1.png, these can be copied from chkCWAPFEnabled-0.png and chkCWAPFEnabled-1.png. See pdf available in about box manuals section for more info
Changes
- [change] migrated to Visual Studio 2026, and C/C++ runtime v145
- [change] changed ZZIS cat command so that it takes/returns the actual filter width and not the slider width position. ZZIS; will return ZZISxxxxx; where xxxxx is 0 padded filter width. ZZIS00500; will set filter width to 500HZ. Symmetrical modes such as AM, SAM will take the full size width, so ZZIS20000; will be +-10k on AM. Note. FilterWdithMode is switched to linear whilst this is applied
- [change] private scope added to in/out firewall rules when [Firewall Check] is used from Setup. Previously was only setting Domain + Public
- [change] reimplemented the code that ensures a form is on screen as there had been occurrences where a form had got 'lost'. Note. this will still fail if a monitor is turned off and windows thinks it is still available as a display surface
- [change] rework of samples provided to RNnoise to bring them into a range more suited to RNnoise. Handles lower signals better
- [change] broadcast kenwood AI messages are now flood controlled to a max rate of 1 message per 200ms
- [change] led indicator scripting has been totally reworked. Now a single script engine is used instead of one per led. Massive memory and performance improvements if you used lots of leds. Also, batches the re-compile until all leds are loaded
- [change] available meter items are listed alphabetically per rx/tx/special group
- [change] on DirectX errors RecreateTarget, DeviceRemoved and DeviceReset, the display engines will now attempt to restart, up to a total of 10 times
- [change] VFOsync re-work. Now has settings in Options-3 tab
- [change] show legacy meters has been changed to hide, to align with other options in Setup->Appearance->Legacy Items. May require you to reapply setting if you want them hidden
- [change] changes to the way meters are restored. Startup speed improvements for systems using lots of meters
- [change] multiple instance detection changed to use global mutex instead of scanning process list
- [change] impulse_cache.dat is removed if wisdom00 is rebuilt
Fixes
- [fix] filter command line args to strip any unexpected characters/unicode
- [fix] you can now enter values into the VAR1/VAR2 filters on the main console. Pressing enter or the box losing focus will set the value
- [fix] issue where low/high values would sometimes not be stored when using the filter configuration settings window/form
- [fix] changing a filter edge in the filter settings config window will now notify all delegates. Fixes issue where filter container would not update
- [fix] fixed a CAT tci/ip server issue where AI broadcast messages could get interleaved between a cat request and reply, which could cause issues for external systems that rely on a correct response, such as HamLib.
- [fix] cw auto mode switch will now not return to previous non cw mode if activated from cw. The return delay now works as expected
- [fix] text overlay now displays vfob mode correctly
- [fix] unnecessary recursive calling when setting PreampMode and AttenuatorData
- [fix] fixed issue where if rtty offset was being used and mode was set to DigL/U then a midi vfo change would cause incorrect frequency calculation (7.100.000 would become 71.000.000)
- [fix] updated to WDSP 1.28 + 1.29, 1.28 reverts the removal of fir filter caching, 1.29 adds new APF types
- [fix] fix where if a radio did not have an rx2 step att available it could prevent rx1 att/s-att setting from being recovered correctly at startup/radio model swap
- [fix] VOX will not ptt if MIC is disabled unless a vac is enabled and VOX uses MIC option is not enabled
- [fix] RIT will not cause spectral overlays such as notches and band stack overlays to move when enabled/disabled after a startup
- [fix] VAC tx/rx gains now restored from TX profile. Previously those TX profile settings were getting overridden by values recovered into the main console UI at startup
