FM Audio very weak and looks like Amplitude Modulation, 7000DLE
KA9UVY
Post by KA9UVY »
With 10 meters working well here I have taken an interest in 10 FM.
When trying to access a few repeaters I have noticed that my audio level is very weak, in fact I seem to still be in AM mode with a change in Amplitude when speaking.
I have tried the Pre-emphasis before and after limiting and also disengaging the Leveler. Turning off the leveler helped a great deal with the change in Amplitude when modulating but I clearly have a center carrier spike and waveform of AM.
The Audio remains quite distant when received on another RX nearby.
If anyone here is using their ANAN 7000dle on FM with Thetis with success please drop me a line and point me into the right direction.
Can this radio do FM 5Khz Dev or not ?
Anan 7000dle last FPGA MKIII
Firmware 2.2.2
Protocol 2 (v4.3)
Thetis 2.10.3.11
Windows 11 PC
73, Robert
KA9UVY
Re: FM Audio very weak and looks like Amplitude Modulation, 7000DLE
FM does look very much like AM, in the sense that there's a carrier and two sidebands.
KA9UVY wrote: Tue Feb 03, 2026 7:56 am When trying to access a few repeaters I have noticed that my audio level is very weak, in fact I seem to still be in AM mode with a change in Amplitude when speaking.
You are definitely not in AM mode. If you are not used to watching FM signal spectra you might be fooled. When operating with FM, you may have to change the scaling on your TX spectrum display to see further down in signal level. Put the carrier spike near the top of the grid and make sure you've got at least 70 dB visible below that point.
Pre-emphasis will cause little to no difference in terms of quieting on the repeater.
Turning off the leveler is exactly the wrong thing to do, regardless of what you are seeing on your transmit spectra. If you want greater average loudness you need to compress your audio dynamic range, which is exactly what the leveler and CFC do.
Other than adjusting the transmit passband, I use the exact same audio settings for SSB as I do for FM ("loud" :D ).
Don't forget that your FM passband settings for RX and TX are found in Settings > DSP > FM. These settings will be saved in the transmit profile.
The default settings for maximum audio frequency are 3KHz. This provides the "traditional" modulation index of 1.63 with 5 KHz deviation and 0.83 with 2.5 KHz deviation. However you are certainly welcome to play with that.
That is what an FM spectrum looks like.
This seems more like an audio chain setup problem than anything else. Is your mic level coming close to 0 dB? If not, add more mic gain. Same for the leveler and CFC and post-EQ output levels. ALC Group levels should hit +1 to +2 dB reliably and often, but not exceed that level.
It has nothing to do with the hardware. I.e. that you are using a 7000 is not important. All Thetis-compatible hardware, from the original Hermes to the G2 to the HL2, is essentially equivalent. They question to ask is whether or not Thetis is set up correctly. All demodulation and demodulation is done in Thetis, other than the direct frequency conversion and amplification nothing relevant is being done in the hardware.
Can Thetis do FM 5 KHz deviation? Of course it can, and does. Simply select the deviation setting you would like to operate with using the controls on the main console screen (right below the mic gain slider).
I've dabbled in FM on our radios and found it to work quite well, making more than a few DX contacts. Indeed, since Warren added the receive limiter function it has worked better than ever :)
KA9UVY
Post by KA9UVY »
Well, Maybe I should have chosen my words more carefully, Instead of LOOKS like let's say BEHAVES like.
My PEP power output increases by at least 50% when speaking on FM. When on AM I get more of an increase and nearly the perfect 4:1 ratio of a fully modulated AM carrier.
I do not have a lot of experience observing the FM waveform but when comparing mine to the others I'm watching, I can see that my sidebands are not well rounded, (some frequencies seem to me standing out and increasing, like AM) and my carrier spike doesn't pull down with modulation.
Besides that my local air check yesterday confirms I sound like Do Do, (weak audio).
I'll try to get my audio level to stay more consistent, and possibly experiment with a different audio driver on my FM profile.
Thanks for any constructive input.
Firmware 2.2.2
Protocol 2 (v4.3)
Thetis 2.10.3.11
Windows 11 PC
73, Robert
KA9UVY
This thread has also got me trying to effect a good FM signal out of Thetis, and I'm having some of the same issues Robert is describing (mainly less than full TUN power during FM TX).
However, another thing that concerns me is that PureSignal doesn't seem to be working on FM (at least not for me).
Is that per design intent?
