Hi All
2x PTT Controll input ?? Why ??
when I run PSDR I use it as remote and I have "Remaud" to control the PTT+MIC+LF and here I use COM5, but if I need to use K9DUR voice keyer then the keyer will not ptt my PSDR, it will not get controll of the com port, it is already take by "Remaud"
also the sasme problem when I runn EME whit dual RX (using VFO A+B) I have 2x wsjt running and
here we have the same problem, the first that "see" com5 have it.
I have try several virituell com ports but whit no louck ! I use at the moment VSPE-64 bit.
any Idea/help from the groupe ???
73" OZ1CT Bent
http://www.df3cb.com/remaud/documentation/
2x PTT Controll input ?? in Powersdr
Re: 2x PTT Controll input ?? in Powersdr
Bent,
If you are using VSPE (as am I), then you need to use the "splitter" type of virtual port. I use the "splitter" type port very successfully to allow two programs to control my KPA500 amplifier.
Make a splitter pair, as, for example COM5 and COM6, where COM5 is the "source" port and COM6 is the shared port.
Put COM5 on PowerSDR, put as many other programs as you wish on COM6.
Or, you might have to do it this way, I'm not 100% certain as I've not done this exactly (again, all port numbers are merely examples):
PowerSDR--(COM 5)--virtual pair--(COM 6) (COM 6)--splitter--(COM 7)--Other programs
Hi Scott
Now it is up and runn as I wanted it to be
I used this setup:
PowerSDR--(COM 5)--virtual pair--(COM 6) (COM 6)--splitter--(COM 7)--All Other programs
TNX fer Help
73" OZ1CT Ben
TNX fer Help
73" OZ1CT Ben
