https://apache-labs.com/al-products/105 ... eiver.html
 Volker--I can't speak to the ANAN-100, but my 100D is whisper quiet. Given that the airflow in the 7000DLE is going to be approximately the same as in the 100D/200D, and that the design now includes a PWM fan controller, it is reasonable to expect that under low power/low duty cycle conditions the 7000 should be very quiet, and perhaps not so quiet when running it at fully power with high duty cycle AM.dl4zbg wrote: What about fan noise e.g. during reception? Is the 7000DLE a "tsunami" like my ANAN 100 (before I changed the fan)?
Or is it more quiet?
No, it does not. It has the "pre-distortion connectors" like the 100D and 200D.iw3fvz wrote:Hello,
the 7000 has the "pre-distortion" connectors like 8000???
Fabio IW3FVZ
 That is to say, it provides an internal coupler for pre-distortion linearization signal routing when operating without an external amplifier, and it is designed to route a signal from an external coupler into the radio via the Bypass connector.
  That is to say, it provides an internal coupler for pre-distortion linearization signal routing when operating without an external amplifier, and it is designed to route a signal from an external coupler into the radio via the Bypass connector. with no real air flow (and improvements/mods done be some hams). I would have expected something like a "lessons learned" design. Providing connectors for a remote fan (on top of the enclosure) is a very good idea for you cannot really cool down the heatsink by means of inside air "flow".....
