PowerSDR mrx Fails to Load
Malcolm
Post by Malcolm »
I have been using PowerSDR 3.4.9 for a couple of months without problems. It now fails top load, stopping half way through with an error message - 'Windows is checking for a solution to this problem' followed a second later by 'A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is found'. It hasn't.
T^he computer runs windows 7, I have a working virus checker and scans report no problems. 'Restoring' the system to an earlier date when working does not resolve the problem. Down loading a new version of 3.4.9 or 3.4.8 result in the same failure.
Has anyone any suggestions?
Malcolm MM0DKQ
Malcolm
Re: PowerSDR mrx Fails to Load
Post by Malcolm »
My apologies! I have now read the post from GW0QW on May 24th and tghe suggest6ion from NC3Z that the current data base was the problem. As suggested I restored a previous database from archive and all is now working.
Many thanks
NC3Z
Post by NC3Z »
Saves me from posting!
GW0DQW
Post by GW0DQW »
Well done Malcolm , first time I have any issue with the database, glad your is ok now.
I do back my database regularly.
Chris
GW0DQW
Return to “PowerSDR mRX”
