I'm going to try my Timewave Navigator modem with my 200-D, and plan to hook up through the rear DB-25. It looks like pin 1 is PTT, pin 21 or 25 for ground, pin 10 or 22 for line out, and pin 12 for line in. Is this correct? Also, is it only RX1 that is routed to the rear? Anyone using one of these modems? Thanks.
Buck ko0y
						Which rear connectors to use for Navigator modem?
Re: Which rear connectors to use for Navigator modem?
Buck,
Pin 10 is what you want for Line Out. Both receivers will have audio on that pin in accordance with the main console Master AF, RX AF, and pan controls.
However, I would strongly recommend you master the intricacies of VAC audio rather than take perfectly good digital audio and turn it into analog, only having to turn it into digital audio again.
Thanks, Scott, I'll use pin 10. I haven't given up on virtual audio. But I have the Navigator hardware sitting here, and would like to run side-by-side comparisons. For VAC, I currently use Voicemeeter's A-B cables, set at 24 bits 48K sample rate and that works pretty well.
Buck ko0y
						Buck ko0y
