I'm trying to let Thetis work with Cw skimmer.
i have all setting VPSE-CAT-Thetis-cw skimmer correctly.
Vpse as pair com 11-12
thetis cat 11-9600-8-1
Cwskimmer/Omnirig  cat 12-9600-8-1
but nothig
On my log if i use the direct cat settign is working if i use omnirig no.
so means there is a problem with thetis and omnirig.
but cwskimmer only use omnirig
any solution?
thanks
						cw skimmer and Thetis
Re: cw skimmer and Thetis
F6GNZ says DDUTIL solves the problem.  See his documentation on the CwSkimmer stie.
http://www.dxatlas.com/CwSkimmer/
de Mike W9MDB
de Mike W9MDB
followed hat info but also other.
Nothing
First problems is Theys don't trasmit the LO Fre infor to cw skimmer.
Vac are correctly configured.
second also DDutl cannot connect by Cat to Thetis and so cannot use that way.
						Nothing
Use an older version of DDUtil. See this post.
Was already trying with old version of DDUTIL
cannot find at all the LEGACY hardware. i'm using P2 and Thesis only. may be was working with P1 only but don't want go back to try.
Also have problem on audio side. there is always a FIX signal (LINE) on the centered frequency.
the real center freq is shifted of 700hz but i cannto find the way to center changing Audio IF value.
