cLicari wrote:Richie...
After deselecting Network Watchdog Thetis ran perfectly, for extended periods, some unattended to test it, for three days! After trying the RF Delays noted above I shut down for the evening, but forgot to return the RF Delay setting value back to 30. Later that night I turned the radio back on and Thetis would not connect after several attempts and was getting a dialog box "No Network Connection. Is it connected and powered" . I checked settings and realized I forgot to return RF Delay value to 30, and did so. I rebooted and Thetis connected but I soon started seeing "seq 41" errors and Thetis would crash in way I've never seen before, not just disconnect. Half of the waterfall display would quit and then Thetis would lock up with the panadapter display signals slowly bleeding down to flatline. I tried several more times with similar results. I tried importing a known good database, no help. At this point I have returned to P1 just so I can operate. Almost didn't even want to report this to the group it being so bizarre, but felt I really should.
Carl
I have a feeling that either you have a network/hardware issue with your computer/network, or there are some odd timing issues with your radio which show up when it is cold? (ie you just turned it on). The reason I say this is that if it was a problem in Thetis, everyone would be reporting it. Don't get hung up on the rf_delay setting that just adds a small sleep delay during mox tx.
I don't know your network setup there, but perhaps borrow/use a laptop, direct connection to radio and try that, just to eliminate everything else.
edit: one of two issues perhaps a) timing issue with radio HW..... b) problem with something on your network when running at 1gbit
