2.6.9
Re: 2.6.9
You're going to laugh but all you need to do is hit the TX FL button that is down at the lower right of the GUI. Right below the TX EQ button.
Re: 2.6.9
W1AEX wrote:You're going to laugh but all you need to do is hit the TX FL button that is down at the lower right of the GUI. Right below the TX EQ button.
Oh my! Rob thank you not only for that but your web site is outstanding! You've helped me on many occasions with it.
Interestingly ... there was a white box there. It had no text in it .. well it did but it was white too. When I clicked it, per your instructions, problem solved and "TX FL" appeared!
73 and thanks again -- Larry W8ER
Re: 2.6.9
Glad it helped Larry. That's curious about the TX FL button not being present. Are you using a custom skin? I have only seen that happen if an older custom skin without the skin updates is being used. You can grab a button pack from my "skins" page (way down at the bottom of the page) and unzip it into the Console folder of the skin you are using and that should bring it up to date.
http://www.w1aex.com/hpsdr/hpsdr.html
Happy New Year and 73, Rob W1AEX
Re: 2.6.9
Don't seem to be able to reach your server Rob ?
Re: 2.6.9
Hmmm... it comes up fine here Tony at the moment, but looking at your timestamp I did an update right around then so the skins page would have been down then. It's all the way across the country in California so when it goes down the hosting company usually gets everything back up quickly.
Re: 2.6.9
So I dont clog up the thread Rob I'll Pm you if thats ok.
Re: 2.6.9
I found the same issue with PS but it also turns off the TX EQ. Confirmed on two different 7000s and two different computers.
Thanks for the great work.
Jim K6JR
Jim K6JR
Re: 2.6.9
Hello all,
I installed Protocol 2 and v2.6.9b6 on my 200D.
I see there is a "receive only" check box on the setup tab.
I checked this and when I key the PTT, I see there is no RF output (which is correct) but the receiver doesn't mute.
It used to use it this way in the 3.4.9 HPSDR with the "disable HF PA" check box checked, it would mute when keyed up with the PTT.
I sometimes use the 200D as a receiver with my K7DYY transmitter.
Do I have something set up incorrectly?
Don W9BHI
Don W9BHI
Re: 2.6.9
I am getting an error box trying to run thetis.
Here is a screen shot.
Re: 2.6.9
I am having the same problem. Today I loaded a new drive with a fresh Windows 10 load and then installed 2.6.9 b6. I am using a 200D and Protocol 1.8 .. the latest I could find for each. The only difference that I have is that I need to end Thetis and start it to get PS working again. Simply turning it off and on does not fix PS for me.W2SDR wrote:There is a problem with Pure Signal enable when its status is saved in a transit profile. For example, when I go from a profile that has Pure Signal enabled to a profile that it’s not enabled and then return to the “enabled” profile, Pure Signal does not work until I turn the button off and then on again.
Frank, W2SDR
--Larry W8ER
Re: 2.6.9
UPDATE
I hope everyone had a good Christmas/New Year. I have not found any time to spend on Thetis over the period, and wont for about another week.
In the meantime, Chris W2PA has a fix to the QSK issue where TX antenna is different to RX antenna. As his changes are important an early build is included here, as well as the source being sent off to Doug. The fix eliminates this problem and any danger of transmitting on the receive only antenna.
Please try : see post #1
73 for now, Richie. - MW0LGE
(12/26/19) c1
-fix: W2PA important QSK fix. QSK can not be used if TX and RX antennas are different. If already enabled and antenna config is changed to use different RX/TX then QSK is disabled. Additional note from Chris (W2PA): As it is, even with QSK turned off, Thetis has a switching issue when using separate antenna jacks for RX and TX. It's caused by the antenna selection relay lagging behind the TR relay slightly. It was there before QSK and is still there. I think it's solvable by applying a different delay in Setup. I'll investigate and we can add it as a guideline to the release notes later.
(12/26/19) c1
Re: 2.6.9
Please send me your database.xml from folder C:\Users\<username>\AppData\Roaming\OpenHPSDR\Thetis, either attach as a post here, or to my email available on QRZ.W9BHI wrote:I am getting an error box trying to run thetis.
Here is a screen shot. Doc1.docx
After that, you will probably be able to get it running if you rename database.xml and restart Thetis. It will need fully re-configuring if you do. Or, perhaps wait until I have had a chance to look at what is causing that error if you can get your database to me.
Cheers, Richie - MW0LGE
Re: 2.6.9
Noted on the PS tx profile issue, and noted on the ToT in status bar. Richie.
Re: 2.6.9
I completly removed everything to do with HPSDR and Thetis.
I reinstalled the 2.6.9 msi and it works now.
I guess something was corrupted.
I am not the sharpest knife in the drawer when it comes to computer stuff but I am learning.
Keep up the good work!
Don W9BHI
Don W9BHI
Re: 2.6.9
After the reinstall of 2.6.9b6 and reentering all of the info that I had copied down into the setup tabs,
I noticed my transmit audio was distorted and clipping on my Mod monitor scope.
I am using the line in audio input connected to my audio rack.
If I reduce the rack output by -15 db, the audio looks and sounds good.
I did an experiment and switched the input on the transmit tab to mic in and found no change in audio level.
It looks as if the line in is being routed to the mic input circuitry whether you select line or mic inputs, which would explain the distortion and clipping.
Is anyone out here seeing this problem?
I am running a 200D .24
Don W9BHI
Don W9BHI
Re: 2.6.9
Don,
It is impossible for the line in to be routed to the mic in. They are completely separate inputs on the CODEC IC. Similarly, the 20dB mic boost setting applies only to the mic path. See this topic:
https://apache-labs.com/community/viewt ... =12&t=2612
Are you sure you just didn't get accidentally bump something in the rack?
Re: 2.6.9
Nothing bumped in the audio rack.
Why would I be able to modulate the radio through the line in when it is optioned for mic input?
When I switch between mic and line there is no difference.
There is a lot of gain in the line input for some reason.
Something in the radio or the software has changed.
It was not like this before the software reinstall.
Thanks.
Don W9BHI
Thanks.
Don W9BHI
Re: 2.6.9
Go back to 2.6.8 and tell us what happens. Use a fresh database, of course. Then go back to 2.6.9 and see what happens, again with a fresh database. This will tell us if it's software or firmware. And what firmware version are you running on the 200D? The latest is 1.8 AFAIK.
Re: 2.6.9
Same thing was happening to me a while back, I dont remember which version of Thetis I was using at the time. To fix it, I ended up reinstalling the latest firmware and it went away. I am also using a 200d.W9BHI wrote:Scott,
Thanks.
Don W9BHI
Perry
W3MMR
Re: 2.6.9
happy new year!
I used the combo 7000DLE, Thetis 2.6.9 C1, pre8 firmware, xvtr LT2S, LZ2US EME amp during the Quadrantids for more than 30 hours - no sleep. no break
- without a glitch. K1JT's WSJT-X 2.1.2 (preferred s/w for MSK144) did also a perfect job, MSHV 2.30 (used for FSK441) crashed a few times during the transition to xmit after a click on AUTO mode or double-click on a decoded callsign when AUTO mode was already active. This did hold down the PTT via CAT interface, but was fixed by restart the crashed software.
I look forward to the further development of Thetis and wish the programmers health, success and joy. Thank you all!
happy new year!
Re: 2.6.9
I wanted to mention of two things I notice in both latest updates for 2.6.9 with (B6 ,C1) in both updates if you're updating a TX profile for AM when you click save to overwrite it after that the profile changes to whichever other profile is been used in SSB, to keep the AM profile you have to manually inserted back in the profile dropbox prior from getting out of mode, otherwise the SSB profile stays when you go back to AM.
(And that's with B6 and C1)
Second I also notice that when you have Dup/PS both engage and PS is correcting and working great, if you go to your setup and play with anything and you hit apply and ok to save whatever you change the PS don't want to work , to make it work again you have to go to the PS button turn off and back on and it goes to normal, and that only happens with the latest update C1 not with B6
I hope this helps for future updates
Albert
N3YV
73's
Albert
N3YV
73's
Re: 2.6.9
I have had a quick look at the issue where PS is seemingly not working when profile is changed and can only assume it is a firmware problem. I can not replicate it here on my 7000dl mk2 running pre8 firmware. I can have a TX profile with PS disabled, switch profile to where it is enabled and it works ok. I have however noticed that I can sometimes get PS into a state where PS has to be toggled, and not always from a profile change.
Something to check, make sure you have enough drive on the profiles to ensure a PS sample can be made.
If you are having this issue please list
Radio:
Firmware:
Thetis version:
Also, the issue Albert reported regarding saving of TXProfiles doing something odd with ssb/am etc, this is fixed and will be out in c2 @ somepoint.
Radio:
Firmware:
Thetis version:
Re: 2.6.9
Richie ... thanks for taking a look for us! I believe that all of us who are finding a problem with PS are running 200D's. I have spent some more time watching PS's behavior and I see it quit even after simply transmitting for about 15 seconds. It will not work again until Thetis is closed and restarted. It obviously is a major problem. I hope the others who are having this problem with PS confirm the model transceiver that they are using.ramdor wrote:I have had a quick look at the issue where PS is seemingly not working when profile is changed and can only assume it is a firmware problem. I can not replicate it here on my 7000dl mk2 running pre8 firmware. ......
I am using Protocol 2 version 1.8 firmware for the 200D downloaded last Thursday from GitHub. Obviously you are not using the same firmware and is there another source or a later version?
Thanks again Richie!
--Larry W8ER
Re: 2.6.9
There is no later version of firmware for the 200D than 1.8.
If you believe that the firmware is at fault, the discussion should be taken to this topic:
https://apache-labs.com/community/viewt ... 3&start=60
You might try down-rev'ing to 1.7 and see if that fixes the problem for you.
It's not a major problem if it has a work-around, which it does (cycle the PS-A button).
Re: 2.6.9
Radio:
Firmware:
Thetis version:
Cheers, Richie
Sorry Richie how careless of me :
Radio: 7000DLE
FW: pre8
T.V. : 2.6.9 C1
C1: PS stops correcting if you open setup to change anything , after apply/ok then PS must be turn off & on to get back to correcting
B6/C1 : AM profile issue ( which you mention is been taking care off for C2)
Thank you Richie
Albert
N3YV
Radio:
Firmware:
Thetis version:
Cheers, Richie
Radio: 7000DLE
FW: pre8
T.V. : 2.6.9 C1
Thank you Richie
Albert
N3YV
Re: 2.6.9
Not happening here. I can leave PS-A on, in and out of settings, save/apply, then mox, and PS is correcting/calibrating no problem. I thought it odd because C1 only has change related to CW QSK stuff, nothing else. Odd indeed.ULTIMAX wrote: C1: PS stops correcting if you open setup to change anything , after apply/ok then PS must be turn off & on to get back to correcting
DO2ZA Erwin
Re: 2.6.9
Hi All,
My 200D Rev. 24, FW 1.8, Thetis 2.6.9 b6 (installed from MSI-File) works perfekt here, no Problems with Setup/saving/add.
Good Work, many, many thanks.
73 Erwin
73 Erwin
Re: 2.6.9
I removed Thetis and the database file.
Reinstalled 2.6.8 and checked the audio inputs and they were working correctly
Dropped in 2.6.9B6 and the inputs are still working.
Obviously there was some corrupt data in the database file causing the issue.
I sure would like to see the "Disable HF PA' in the "Ant/Filters" tab get fixed.
I have asked two different people with 200D's that say the "Disable HF PA" doesn't work for them either.
Thanks for all you guys do for this hobby.
Don W9BHI
Don W9BHI
Re: 2.6.9
I have a little problem with Pure Signal since version 2.6.9_C1. I use about 15 seconds and the Pure Signal no longer works. The PS-A button is still working, but the two green Correcting and Feedback boxes turn black. Tried several times always the same problem.
Version 2.6.9_B6 and previous version work well. Installation with new database.
Another less important remark, at the first installation the microphone did not work, it has to function correctly after restarting software
Anan100D Angelia_Protocol_2_v11.7_7-15-18
Michel
Michel
Re: 2.6.9
only changes to b6 to make c1 :VA2EY wrote:I have a little problem with Pure Signal since version 2.6.9_C1. I use about 15 seconds and the Pure Signal no longer works. The PS-A button is still working, but the two green Correcting and Feedback boxes turn black. Tried several times always the same problem.
Michel
fix for qsk antenna rx/tx issue - would not impact PS
andomeda changes - would not impact PS
I have a feeling that reports of PS-A working in b6 and not in c1 are somewhat bogus imo, but stranger things have happened i'm sure.
