New -10/-100 16-BIT Hermes Protocol 2 Firmware Topic
N8RWS
Re: New -10/-100 16-BIT Hermes Protocol 2 Firmware Topic
Post by N8RWS »
Also, the TX bandwidth error does not occur if sample rate is 192000
Jeff
N8RWS wrote:Good day,
Wondering if anyone found fix for TX bandwidth error in dup mode? The visual in the display looks to be double the bandwidth I am actually running. This occurs only when pure signal is on.
I am running: ANAN 100, V2.8.11~2/V10.8.0, 21k8, Firmware: 2 10.8 pre20
N8RWS
Post by N8RWS »
Hi Rick, hope all is well, I tried to send a PM but it is stuck in outbox !!
I am running: ANAN 100, Thetis v2.9.0.5 x64 (4/21/22), Firmware: Protocol 2v 10.8.0 pre20
Not a huge deal but hoping its an easy fix: The TX bandwidth visual (with DUP on) in the display looks to be double the bandwidth I am actually running when pure signal is on and I am using over 194000 sample rate.
I would like to know if there is another version of the firmware that solves this issue or if there is any chance a new version is in the works.
Other than this small issue, everything is working very well.
Jeff
N8RWS
DH1KLM
Post by DH1KLM »
I'm pretty sure I've read something about this behavior in the forum before. But I can't find the post.
I suspect that it is a Thetis problem. I would like to almost rule out the firmware.
Since Thetis v2.9.0.5 is not an official version, it may suffer from bugs.
You might try the TAPR release "Thetis-v2.9.0.3" or Richie's latest "Thetis-v2.9.0.6".
PS. This could also be caused by a corrupted database.
N8RWS
Post by N8RWS »
DH1KLM wrote:I'm pretty sure I've read something about this behavior in the forum before. But I can't find the post.
Thank you for the feedback. I just reset database and try, still problem. Then I removed all previous version of Thetis and install the TAPR 2.9.0.3 and then Richie's 2.9.0.6. Same problem occur with each
N8RWS
Post by N8RWS »
N8RWS wrote:Also, the TX bandwidth error does not occur if sample rate is 192000
Jeff
Here are a few points that may help track down this issue. The problem only occurs if RX1 sample rate is over 192000 and PureSignal is fully enabled. If I perform a single cal with two-tone it will lock in, correct and not display double the bandwidth as I am transmitting. As soon as I click the PS button and PureSignal starts sampling it will display double the bandwidth as I am transmitting .
I am still running firmware: 2 10.8 pre20 which is working the best of all releases so far. I am running Thetis v2.9.0.5 but have tried v2.9.0.3 and I reset the database with no change to the problem.
I realize not many are running these old ANAN 100's so this is surely not a priority, it would be sweet if someone could dial in the firmware to address this issue !!
Thank you
Jeff
