2.7.0
va2na
Re: 2.7.0
Post by va2na »
I have reset my database just to be sure nothing is coming from there.
I got diversity now working but still strange issue : Turning off ( disabled )Diversity put my main receive on ADC1 ext antenna... Trying to switch back and forth ADC 0 to 1 and the to 0 do nothing...
Guillaume
Re: 2.7.0
What model ANAN do you have?
va2na
Re: 2.7.0
Post by va2na »
w-u-2-o wrote:What model ANAN do you have?
Anan 8000 DLE firmware 2.0B and Thetis 2.7.0 a3
Re: 2.7.0
Hate to say it, but it may be time to delete the entire thing and start over. This is a PowerSDR topic but it also references Thetis:
https://apache-labs.com/community/viewt ... f=6&t=2975
Re: 2.7.0
via a PM, added here, just as a reminder, when i (or someone) goes through the thread to do a catch-up at some point
I own a 100D and select this in "General - H/W Select".
In "General - Ant/Filters - HPF/LPF" the HPF section is missing
va2na
Re: 2.7.0
Post by va2na »
w-u-2-o wrote:Hate to say it, but it may be time to delete the entire thing and start over. This is a PowerSDR topic but it also references Thetis:
Sorry for the delay Scott, but yes it time to do this...Puresignal is not working anymore too...
Re: 2.7.0
So bummed there has been no more of the cool updates :(
nico
Re: 2.7.0
Post by nico »
NC3Z wrote:So bummed there has been no more of the cool updates :(
Yes please - is there anything we can do to help Richie and others? :roll: :roll: :roll:
W4GM
Re: 2.7.0
Post by W4GM »
I also need a FIX!!!
W9BHI
Re: 2.7.0
Post by W9BHI »
Anyone notice the extra -20db line in the attenuator settings?
I am running 2.7.0 A3, P2 v1.9 on 200D .24.
I reset the data base just to be sure but it is the same.
Here is the screen shot.
Don W9BHI
Screenshot (1).png (240.78 KiB) Viewed 31708 times
Re: 2.7.0
I only see -10 -20 -30 on mine
DK1WP
Re: 2.7.0
Post by DK1WP »
W9BHI wrote:Anyone notice the extra -20db line in the attenuator settings?
That's not new.
It's always been that way.
73 Marcus
Marcus
W4WMT
Re: 2.7.0
Post by W4WMT »
Don W9BHI
Hi Don,
Before Scott kicks this thread off the topic, let me just comment: The Orion SDR board and the 200D PA board both had an assortment of fixed attenuators that together could be switched in and out to provide various combinations of attenuation. This is legacy stuff that is now considered to be deprecated. It is highly recommended that you set all that stuff to zero and then enable the 31dB step attenuator in the Setup\Options menu.
dj1yr
Re: 2.7.0
Post by dj1yr »
with a double click on the ATT font you can switch between Step ATT and old ATT, this function is old
W9BHI
Re: 2.7.0
Post by W9BHI »
I switched the software to 7000dle and the attenuator selection shows 10, 20, 30.
It is a 200d software issue.
Not really a problem I guess.
Don
Re: 2.7.0
Not a huge mystery, except that it is because there is no documentation except for what you read here.
Until the 8000, all of the hardware was built with two switchable attenuators on the RF board: a 10dB attenuator and a 20dB attenuator. Thus there was the so-called "ATT" mode where you could select one, the other, or both, to get 10, 20 or 30dB of attenuation. To get more the step attenuator was added in 10dB increments. Some time ago several of us tried to figure out why 20dB occurred more than once on the menu but failed, the code is that hopelessly convoluted.
You can, of course, change to "S-ATT" mode and use the step attenuator to change attenuation in 1dB steps. IMHO this is the preferred mode of operation. The maximum step attenuator setting is 31dB.
Starting with the 8000, and in the follow on models, the 7000 and soon the 6000, it was realized that the additional attenuators on the RF board did not add any value and they were not incorporated. Hence the change to the UI in PowerSDR and Thetis for those models. In ATT mode you get three convenient 10dB steps. In S-ATT mode you get 1dB steps. But in both modes only the step attenuator is being used because it is the only attenuator in the receive path.
FM5GB
Re: 2.7.0
Post by FM5GB »
Hi all
Same here (an extra -20 dB position)
200D. Thetis 2.6.9,
I can live with it.
73s Phil FM5GB
dalemitchell
Re: 2.7.0
Post by dalemitchell »
I assume version 2.7.0 is being updated.
If so where can I download the latest version?
Dale W0GD
Re: 2.7.0
dalemitchell wrote:I assume version 2.7.0 is being updated.
Dale W0GD
Just a little reading away, Dale. I'd recommend perusing more of the forum, you will find a lot of useful information.
First read and follow the "Latest Releases" topic in the Thetis sub-forum, here: https://apache-labs.com/community/viewforum.php?f=9 and install a fresh, clean copy of 2.6.9, which is the current "official" release.
Then go back to the very first post in this topic, the 2.7.0 topic, and follow the instructions there.
k6avp
Re: 2.7.0 Feature Request - Tune Timeout
Post by k6avp »
I just found I had left my radio on tune for a good 30min - lucky I have tune set for pretty low power. Hope I never do that again, but I am thinking a Tune timeout would be nice.
LarryW
Re: 2.7.0 Another Software Request
Post by LarryW »
Not sure if this is the right place for this post but here is goes----
I have set up my SSB audio on the rig and LOVE the sound. Sold all the W2IHY stuff as we don't need that anymore.
My request would be for a option to put just a tad bit of ambience (echo) in the tail end of the audio. I know this sometimes becomes a very hot topic in other forums as there always seems to be someone that has the level maxed out.
If your a audio buff then you will know what I am talking about. It don't take much--- usually the lowest setting is all that is needed.
Hope this sparks some interest!
73 All
Larry N7ZDR
7000 mkll Thetis v2.8.11 21k3
P2_v2.0b
Re: 2.7.0
Hi Larry, voicemeeter banana or potato software can do this for you if you use a digital interface for your mic. Probably needs its own topic though as its not planned for Thetis as far as I know so perhaps Scott can split this off.
Re: 2.7.0
Larry,
Tony beat me to it. I don't think you are going to get much traction on that feature request. It's like asking for "roger beeps" ;)
However, there are ways to do what you want. I suggest you start a topic in the Digital (Virtual) Audio sub-forum if you'd like to pursue something.
LarryW
Re: 2.7.0
Post by LarryW »
Thanks Tony and Scott----in reference to the Roger Beep, I under stand exactly what you mean for sure.
I have yet to get involved with VAC on the audio side of things as we are still learning the ropes and have just stuck with the mic into the rig.
Have a great day!
Larry
P2_v2.0b
w2ner
Re: 2.7.0
Post by w2ner »
It does not look like Riche is going to spend any more time on updates, its been a long time. I understand if he got a bit burnt out. I wonder what the future is going to be for this interface. Not much of a choice out there which is not a good thing for the life of Apache Labs.
W9BHI
Re: 2.7.0
Post by W9BHI »
So, Richie actually told you this?
I had an e mail conversation with him about a month ago and he said that he prefers to do his ham radio and programming
in the fall and winter months as he likes to be out doors during the summer months and has other things that are more important to him during that time.
I don't think that after all of the work he has put into Thetis that he would just throw in the towel.
Be patient, he will be back when he is ready.
DG9FDA
Re: 2.7.0
Post by DG9FDA »
Here 100D, Thetis v2.7.0 (3/1/20) MW0LGE (a3), Metis_Angelia_Protocol_2_v12.1_pre4. The Drive slider position is not stored wether in the TX profile (what I like to have) nor in the Database. When I shut down Thetis and start again I have Drive slider position 100 again. This is not very funny because I like to use my SPE1K-FA and need only 20 Watts for legal limit. Any information for me?
The second problem I have is that under "General - Ant/Filters - HPF/LPF" the HPF table is missing. There is no information about this problem in the forum up to now...
Thanks, Georg, DG9FDA
Anan 100D first edition, Thetis v2.10.3.6 x64, Protocol 2 Version 12.1.8
KA1GXR
Re: 2.7.0
Post by KA1GXR »
DG9FDA wrote:Here 100D, Thetis v2.7.0 (3/1/20) MW0LGE (a3), Metis_Angelia_Protocol_2_v12.1_pre4. The Drive slider position is not stored wether in the TX profile (what I like to have) nor in the Database. When I shut down Thetis and start again I have Drive slider position 100 again. This is not very funny because I like to use my SPE1K-FA and need only 20 Watts for legal limit. Any information for me?
I suspect you could benefit from a database reset. Save current database and reset to defaults.
KA1GXR
DG9FDA
Re: 2.7.0
Post by DG9FDA »
Thomas,
thank you for your hint. I am very sorry but both problems are there after Database reset. Any other information?
Thanks and 73 de Georg, DG9FDA
DK1WP
Re: 2.7.0
Post by DK1WP »
Hello Georg,
i guess that your DJ Control MP3 e2 is set to 100% with the gain control. With the start of Thetis this position is taken over. Turn the knob down and it should work.
Marcus
Locked
