Page 2 of 2
Re: Seq Errors Explained
Posted: Sun Oct 18, 2020 2:37 am
by tok2010
Hi All,
I'm running Thetis v2.8.8 (x64) here. It works great with FW v2.0b.
I've just had SEQ ERROR, then I report it. My PC is equipped with i5-3570K. My Orion MKII is directly connected to the PC.
- seq error.PNG (25.9 KiB) Viewed 73950 times
Tokio
ja1cca
Posted: Sun Oct 18, 2020 7:13 am
by DH1KLM
as Scott mentioned here
https://apache-labs.com/community/viewt ... ror#p12403
there is no longer a need to report seq errors.
Posted: Sun Oct 18, 2020 11:46 am
Thanks for reminding me it was past time to update the first post in this topic, Sigi!
Posted: Sun Oct 18, 2020 6:01 pm
Scott, you've stated elsewhere that you've turned off Seq Error reporting. Where can I find such a toggle?
Posted: Sun Oct 18, 2020 10:07 pm
Good point, Mark. I have added it to the original post.
Posted: Mon Oct 19, 2020 11:33 pm
by N4XD
The set up: Anan 7000dle Mk2
Thetis V 2.8.9
CPU older i7 running at 2.89Ghz or such
W10
Was having lots of sequence errors which caused audio glitches.
To solve this I used a windows program called prio (can get it, or one that does the same thing here:
https://www.raymond.cc/blog/permanently ... with-prio/
It works in conjunction with task manager. Right click on the task, change priority, and done. I changed Thetis to high vs normal and, so far, no more sequence errors. The link has several other programs to choose from.
Prio is supposed to make the changes permanent which isn't the default with Task Manager.
Prio is free and small.
Hope this helps someone!
Ron
N4XD
Posted: Wed Oct 21, 2020 12:22 pm
by N4QNT
Great advice Ron.. Thanks for the info, Seq Errors are gone
Posted: Wed Oct 21, 2020 12:59 pm
by Tony EI7BMB
Thanks Ron great tool
Posted: Wed Oct 21, 2020 1:05 pm
by PD3LK
Hello Ron, does your sollution act better (or different) then the Thetis build-in prio option? (see pict) regards, Leon
Posted: Thu Feb 25, 2021 1:35 pm
by N4XD
Another update on sequence errors and audio glitches.
A while back I upgraded my computer to a gen 4 or 5 I7 processor. eliminated most issues but, when web pages were updated or accessed, still had some very short audio glitches. Not an issue except when contesting.
Today I installed a SSD that I cloned from my other rotating drive. So far, in very preliminary testing (accessing several web pages) the audio glitches are gone.
I will continue to monitor this to see if the simple change of moving to the ssd solves this issue. If it does, its a very low cost solution.
By the way, I used the free program, AOMEI backup to clone the drives. The free version does this without issue.
Ron
N4XD
Posted: Sat May 08, 2021 3:02 pm
by cLicari
I just started getting this SEQ error msg and is causing dropouts on transmit.
Anyone have thoughts on a reason or fix would be much appreciated.
Thx
Carl
NX5T
Posted: Sat May 08, 2021 9:00 pm
by ea3aqr
cLicari wrote:I just started getting this SEQ error msg and is causing dropouts on transmit.
Thx
Carl
NX5T
If it is after updating Windows 10 to version 20H2, take a look at:
https://apache-labs.com/community/viewt ... =13&t=3780
Posted: Sun May 09, 2021 3:05 am
by cLicari
I had one Windows10 update on 5/1/2021 called 2004 forx64 based systems (KB4023057).
This being 5/8/2021 seems like it just started one or two days ago, but started getting another SEQ error closer to the Win10 update that is intermittent and lasts a fraction of a second causing receive audio dropouts. My audio is analog, I do not use VAC. Would the fixes EA3AQR posted still help my issues?
Thx
Carl
NX5T
Posted: Sun May 09, 2021 12:12 pm
by kc2rgw
cLicari wrote:I had one Windows10 update on 5/1/2021 called 2004 forx64 based systems (KB4023057).
Thx
Carl
NX5T
The network throttling registry key change could help possibly. All the data, visual and audio goes to and from the computer and any jitter or packet loss affects either/both.
Posted: Mon May 10, 2021 11:24 am
by cLicari
I made the Network Throttling Index change in Windows 10 registry and all of the SEQ errors have ended.
Thx to all,
Carl
NX5T
Posted: Mon May 10, 2021 2:05 pm
by ea3aqr
cLicari wrote:I made the Network Throttling Index change in Windows 10 registry and all of the SEQ errors have ended.
Thx to all,
Carl
NX5T
Nice!
Posted: Thu May 13, 2021 8:46 am
by I2NOY
Thx to all,
Carl
NX5T
Carl, can you be more specific?
If you can post the registry change, I think, who is skilled enough to change this value, can solve networking issues.
Posted: Thu May 13, 2021 9:37 am
by DH1KLM
Posted: Thu May 13, 2021 9:48 am
by PD3LK
Posted: Fri May 14, 2021 8:48 am
by I2NOY
Many thanks!
Posted: Mon May 16, 2022 12:43 am
by w8er
PaulManc wrote:I am sure you are correct, Scott.
Before I do....one thing bugging me is my Cat5e cable going downstairs to my router around 30ft. Ive been thinking about installing a seperate intel gigabit network card in my PC (configuring as per Rob w1aex) and then running a short cat6/7 cable to the 7000dle mkii. Could this improve my chances or is it wishful thinking?
TIA
Hi Paul,
I'm sorry to be responding so late to your question but I just happened across it. My hope is that I might help others that pop a question like yours.
With a 7000DLE MkII and after an upgrade to P2, I started having the dreaded SEQ ERRs also. Putting the additional network card in the computer and giving the 7000 it's own connection was the solution that worked for me, that is along with the Registry mod that controls Windows "THROTTLING" Here's what I did and the result:
Homebrew Desktop : i9-11900K 32G Asus MB NVMe 500G Samsung Windows 10 and 11 Fixed IP's on most devices.
1. Replaced the switches in my home network ---> No help
2. Reconfigured Home network. Put switch at each location that had network devices connected (3) Star connected to router. ---> No Help
3. Replaced 5E network cables with Cat 7 cables ---> No help
4. Tried different Firmware (P2) versions (No issues with P1) Various probs with other P2 versions ---> No help
5. Dropped in Intel Network card and connected 7000 to it . Fixed IP's --- Reduced SEQ ERRs to almost zero!
6. Changed Windows Registry "throttling" setting ---> Eliminated SEQ ERRs entirely.
I also tried using an Intel NUC and attached 7000 to regular RJ45 Gigabit port AND used Remote Desktop connection VIA WiFi back to HB desktop. (worked very very well)
I'm sure that you got it running because you were headed in the right direction. Other's may just be starting.
73 --Larry W8ER
Posted: Fri May 20, 2022 8:11 pm
by PaulManc
HI Larry !
I did the NIC some time ago and followed Robs W1AEX in the most part on my win10 machine. Using 2.0b FW, I still had some errors then I moved the radio from the desk to a shelf BUT with a 3" hole beneath the fan. I did the throttling index mod kindly provided by Jordi and Scott and the latest Thetis...........poooof gone!!. Of course now our own resident genius MW0LGE has added it into Thetis as an option.
Glad to hear you are all set with your 7000DLE and thank you for reaching out and explaining for others.
73 Paul
Posted: Mon Oct 10, 2022 1:06 am
by Pete4638
I have a 7000DLE MKII with the network cable connected directly to my laptop. I never get a sequence error, until I start up Ham Radio Deluxe; then I get multiple sequence errors. I don't know if there is something that I can do in setting for Thetis or Ham Radio Deluxe that would do abate the sequence errors. Fortunately, the sequence errors do not appear to affect the functionality of the radio.
Peter Bucy - KD4CQZ
