Page 2 of 2
Re: VAC under/overflows due to changes in how Windows handles Timer resolution
Posted: Wed May 05, 2021 9:40 am
by ea3aqr
Tony EI7BMB wrote:
ea3aqr wrote:
Tony EI7BMB wrote:I have tried going back to previous version of windows and although the process seemed to go ok the problem remains.
Windows 10 v. 1903?
Windows 10.0.18363 Build 18363
This is W10 v.1909.
I don't remember if V.1909 is also afected by this issue, for sure v.1903 (13362) isn't.
Posted: Wed May 05, 2021 9:43 am
Windows version 20H2 on an i7-6700K, no under/overflows running MOTU M4 ASIO thru Voicemeeter Potato with 0-0 Ring Buffers and 0-0 PortAudio. Prolly should count my blessings!
Posted: Wed May 05, 2021 9:56 am
by Tony EI7BMB
You are right of course , I am back to 1909 which was installed on 14/10/2019 but it seems the roll back to this did not revert fully as I still have the problem.
ea3aqr wrote:
This is W10 v.1909.
Edit: I may have misspoken Re testing on 1909 shows the following correction
FireShot Capture 148 - - .png (13.84 KiB) Viewed 18997 times
Although the request is showing as outstanding a helpful person on the voicemeeter forum gave the following info
"It's normal for a timer request to be 'outstanding' - Imagine this scenario:
App 1 requests 1ms timer
App 2 requests 1ms timer
App 1 exits
What will occur is:
Step 1 will result in decreasing the timer period per App 1's request.
Step 2 will result in the timer not being altered as it is already in the desired state. The request is kept.
Step 3 will result in App 1's timer request being removed, thus allowing the timer to return to default state...
However, the request from App 2 is still outstanding, and now it takes effect.
Accordingly, no change is made to the timer.
Without this 'outstanding' request to change the timer config, step 3 would result in App 1's request being cleared, and the timer returning to normal, leaving App 2 with the wrong timer config."
Posted: Wed May 05, 2021 1:16 pm
by Tony EI7BMB
Hi Mark, I wonder if you know of any other programs running that might be setting the clock to the correct setting , 10000 I believe for Thetis , IE one that windows 10 recognizes the command like another audio program running in the background perhaps? I'm just trying to figure out why some are affected and not others
K1LSB wrote:Windows version 20H2 on an i7-6700K, no under/overflows running MOTU M4 ASIO thru Voicemeeter Potato with 0-0 Ring Buffers and 0-0 PortAudio. Prolly should count my blessings!
Posted: Wed May 05, 2021 2:14 pm
Tony,
I'm at work right now so I can't verify, but I don't think there's anything else running on my system that might be controlling audio.
I do know that Windows Sound Scheme is set to "No Sounds". Maybe that's relevant, I dunno..
Posted: Wed May 05, 2021 2:21 pm
by ea3aqr
K1LSB wrote:Tony,
Tested with windows sounds deactivated and timer resolution not changing on request
Posted: Wed May 05, 2021 2:41 pm
by ea3aqr
Tony EI7BMB wrote:Hi Mark, I wonder if you know of any other programs running that might be setting the clock to the correct setting , 10000 I believe for Thetis , IE one that windows 10 recognizes the command like another audio program running in the background perhaps? I'm just trying to figure out why some are affected and not others
Tony,
I think it is not a matter of installed software...
I have a second ssd for debuging this isue with just the default Windows 10 v1903 install, all needed drivers and Thetis.
It works rock solid as it used to do on my main OS. After updating the debug OS to v20H2 via Windows Update all is messed again. I've also installed a fresh W10 v20H2 to discard problems with the Windows update process itself but, unfortunately, the fresh W10 v20H2 also fails.
Rolling back to v1903 (via Windows update or installing a fresh OS) and all is working fine.
That is for sure a problem with the update.
Unfortunately I can no go further by myself and looks like that the developer team is not so much interested in this issue.
Also is a bit dissaponting the lack of cooperation from other forum members (just 2 Powercfg reports after 280 views).
Posted: Wed May 05, 2021 3:21 pm
by Tony EI7BMB
Yes more powercfg reports would be helpful especially from guys who have latest windows 10 and are not experiencing any problems. To be honest as this is all done by volunteers I'm not sure there is a developer team right now. Maybe Abhi from Apache labs could have someone investigate the issue.
Mark thanks for your reply.
Posted: Wed May 05, 2021 4:08 pm
by W4WMT
Hi All,
Thetis' VAC1 & VAC2 use the PortAudio library to do all its IO to the sound hardware drivers. I subscribe to the PortAudio mail reflector and scan
or read all the messages that come across. I have seen zero chatter about this issue amongst the PA developers. FWIW.
73, Bryan W4WMT
Posted: Wed May 05, 2021 4:14 pm
by ea3aqr
Look like finally I've solved the issue with some registry tweaks! :D
Give me some more time to test it properly and I will post the solution.
Tony, in a few minutes you'll have a PM!
Posted: Wed May 05, 2021 4:17 pm
by Tony EI7BMB
Thanks for the info Bryan, seems its not a widespread problem
W4WMT wrote:Hi All,
73, Bryan W4WMT
Posted: Wed May 05, 2021 4:18 pm
by Tony EI7BMB
Gracias mi amigo :)
ea3aqr wrote:Look like finally I've solved the issue with some registry tweaks! :D
Posted: Wed May 05, 2021 4:35 pm
by ea3aqr
Tony EI7BMB wrote:Gracias mi amigo :)
Tony, check you PMs
Posted: Wed May 05, 2021 4:43 pm
In the FWIW department:
I've been playing with this for two days now, just to see what's what. I don't think the reports in powercfg have a lot of meaning, but that's just a gut feel. I get the same reports as everyone else.
One thing I did notice is that I was having some very slight ticks/pops on the audio. I changed from:
ASIO, 96KHz, Buffer 128, Portaudio both 0, Ringbuffer 5 and 8
to:
ASIO, 96KHz, Buffer 512, Portaudio both 0, Ringbuffer 0 and 0
And this made the audio buttery smooth. I have some "leakage" of under/overruns in VAC, but these are never audible.
These seem to be near equivalents in terms of latency, i.e. 1.3ms of buffer plus 5ms+ of ringbuffer vs. 5.2ms of buffer plus no ringbuffer.
Also, the weak link in the chain for me is Reaper DAW. If I use Voicemeeter alone I can go with the former setting and Ringbuffer at 2.
Finally, if there is really a culprit (perhaps only for Ryzen users) in 20H2 et al, then it probably has to do with blocking channelmaster.dll calls for IF processing and nothing at all to do with PortAudio, VAC and Windows audio stuff. Someone can prove this by seeing if they get pops/clicks/glitches on the ANAN headphone or speaker outputs, neither of which has anything at all to do with VAC or Windows audio stuff.
Posted: Wed May 05, 2021 4:49 pm
by ea3aqr
w-u-2-o wrote:In the FWIW department:
to:
After some registry tweaks my system is rock solid again at 3/4 ms IN/OUT.
I've sent those tweaks to Tony for testing. I will post the solution if it also works in his PC.
My powercfg report still shows a current timer resolution of 15.6ms, but no more under/overflows on VAC.
Posted: Wed May 05, 2021 5:08 pm
by rbduck
ea3aqr wrote:After some registry tweaks my system is rock solid again at 3/4 ms IN/OUT.
It would really be nice if you have the issue resolved with registry tweaks.
I read that suggested article about the changes in Windows 10. I understand what the writer is saying but at the end it seems all he could offer was speculation as to why they made the change. It was interesting reading.
Thank you for your diligence with this issue.
Posted: Wed May 05, 2021 5:13 pm
by ea3aqr
After +30 min runing Thetis it is working like a charm!. VAC set to 3/4 and radio behaves like on W10 v.1903
Waiting the results from Tony to post the solution.
Posted: Wed May 05, 2021 5:21 pm
What do you mean by "VAC set to 3/4"?
Posted: Wed May 05, 2021 5:28 pm
FWIW my VAC settings are 256 buffers and 48K sample rate, ASIO (0/0 Ringbuffers and 0/0 PortAudio as noted earlier).
Just curious, may I ask why you decided on 96K sample rate?
TIA,
Posted: Wed May 05, 2021 5:29 pm
by ea3aqr
K1LSB wrote:What do you mean by "VAC set to 3/4"?
RingBuffer set at 3ms IN and 4 ms OUT
Posted: Wed May 05, 2021 5:30 pm
Ah, I understand now, thanks.
Posted: Wed May 05, 2021 5:46 pm
by ea3aqr
My VAC settings are:
Buffer size: 64
Sample rate: 96000
Ring Buffer IN: 3
Ring Buffer OUT: 4
Port Audio: both at 0
Posted: Wed May 05, 2021 6:36 pm
by Tony EI7BMB
I have implemented Jordi's (EA3AQR) fix and audio now looks very solid on Windows 20H2. Many thanks to Jordi for coming up with this solution.
Posted: Wed May 05, 2021 6:51 pm
by rbduck
Yes Indeed. I have to say that Jordi did it. So far am running the same timings that Jordi posted above with the exception I was only able to use 5 in and 5 out on the Ring Buffer. I am not complaining at all it' is much better than what it was. Thank you Jordi for your help.
Posted: Wed May 05, 2021 7:14 pm
by ea3aqr
Tony and Ruben, I'm very happy it has worked!
I'm going to take a break and relax enjoying a smoked scottish (I'm sorry Tony ;) ) single malt whisky after dinner.
It was a 30 days hard work for debuging this issue...
I'll open a new post (linked from this) with my solution.
I'm a happy camper! :D :D :D
Posted: Wed May 05, 2021 9:05 pm
by ea3aqr
