Locked
m0cpy
Post by m0cpy »
I had to do an uninstall
I did an over-the-top install, and everything seems to be working, but I can't tell if it is 2.9.0.5 or not. The title bar says "Thetis v2.9.0 x64 (4/4/22) (Protocol 2 v2.1.18) MW0LGE rev4"
NJ2US
Post by NJ2US »
I did an uninstall, then ran the msi and my title bar says " Thetis v2.9.0.5x64 ((4/21/22) (Protocol 2 v2.1.18) MW0LGE
The fresh install retained all my database info.
Jeff NJ2US
interesting, just ran an install on mine, and it went over the top, it should say 2.9.0.5 in the title bar. Best to uninstall/reinstall in that case. Not like it takes long to do. I will update post 1.
rbduck
Post by rbduck »
Mine installed over the top with no issues. I will do the uninstall/install thing next time. I was done before I remembered I may have needed to do that.
kc2rgw
Post by kc2rgw »
Went from one of the k series pre-releases to 2.9.0.5, it needed a remove and a re-install, then no troubles. Symptom was, the radio just didn't "start", software powered up but nothing "running".
The power profiles are a great idea, thanks.
kc2rgw
Post by kc2rgw »
Want / Wish
In Collapsed mode the PWR doesn't indicate current value/position, maybe populate the hover over with the value?
Also in Collapsed mode I would like a VAC over/underflow indicator, it could be tucked in the bottom status bar?
dl5tt
Post by dl5tt »
Hey Richie,
tnx for the new version (2.9.0.5), here no problem with installing (after deinstalling with W10-system procedure).
WANTWISH
a) Is it possible, to include the function / checkbox "adjust min to noise floor..." in your new pulldown buttons below the waterfall? Sometimes it is usefull to enable / disable this (very nice) feature with only one mouse click.
2022-04-21 17_00_23-Setup.png (4.27 KiB) Viewed 27583 times
b) I can not increase the band width with the mouse wheel, if the "Low"-value is greater 0. Btw I am using this function in CW-mode starting with a filter width of 400 Hz.
2022-04-21 17_10_04-.png (16.77 KiB) Viewed 27583 times
Only if Low is 0, then the mouse wheel works in the upper direction. Is this a problem with my database?
Btw: It is great, that your provided source-ZIP-files are usable in VS without any obstacles, concerning compiling and building own versions.
Thank you again and again for your impressive work.
73 de Josef
dl5tt
Post by dl5tt »
kc2rgw wrote:Went from one of the k series pre-releases to 2.9.0.5, it needed a remove and a re-install, then no troubles. Symptom was, the radio just didn't "start", software powered up but nothing "running".
I have the same problem after pressing START in Thetis and nothing happens with the RADIO and finally I get the question ".....is it connected and powered". I quit this message 2-4 times and then the radio starts.
2022-04-21 18_06_49-apache-labs.com - Edit post.png (11.5 KiB) Viewed 27573 times
But this behavior is not reliable replicable.
I didn't find the reason for this.
Has any one an idea for this behavior?
73 Josef
dl5tt wrote: b) I can not increase the band width with the mouse wheel, if the "Low"-value is greater 0. Btw I am using this function in CW-mode starting with a filter width of 400 Hz.
this is a bug, and no, not a problem with the db, thanks for the report.
re the connection issue. If this is intermittent then it could be any number of issues, from network, to hardware, to pc, to firewall, to other software running... etc...etc
Uninstall/reinstall had the desired effect.
Digging the new offset setting for the automatic minimum panadapter level :)
m1tzr
Post by m1tzr »
Install over the top failed, error Tune drv (I think it said, didn't save the screen shot)
Uninstalled and re installed without issue.
Can the power profiles be assigned to mode?
Thanks for my new toys Richie.
Paul
EA1DAV
Post by EA1DAV »
WANTWISH
CW audio monitor when use VAC.
Thanks by all your work Richie.
Jesus.
EA1DAV wrote:WANTWISH
This has been a Holy Grail for many years.
The problem is that the original design team never thought that real-time CW sidetone on the PC audio interface was possible. We know this to be an incorrect assessment since the full-break-in QSK capability was implemented in Thetis/P2 for Orion and Orion MKII based hardware.
Unfortunately, for those who have a key or paddle attached to the hardware input on an ANAN, there is no support in the firmware for the necessary high speed signaling to come back from the hardware to the PC and be made into sidetone.
However all is not lost.
If the key/paddle was instead attached to a PC serial port and enabled in Setup > DSP > CW > Connections, then the problem becomes strictly that of software. Thetis could be modified to produce the necessary sidetone with sufficiently low latency on the VAC interface.
It is worth noting that this configuration does work for full-break-in QSK on Thetis/P2/Orion platforms.
m1tzr wrote:Install over the top failed, error Tune drv (I think it said, didn't save the screen shot)
Paul
yes I have updated the text in post 1 and the github repo to advise to uninstall/reinstall. After reading WiX details on upgrades, it is only triggered if a value in the first 3 digits change, 2.9.0. However on some machines, including mine, then a change in revision does cause an over-write/upgrade, so not exactly consistent.
Re the mode, no. Of course it could be coded, but I think this stage of flexibility is just enough right now.
EA1DAV
Post by EA1DAV »
In my current setup the CW paddle is direct to a com port as you point, and setup, dsp,cw configured. Also in contests, I use a virtual port in the same machine to keying Thetis, so more close is imposible. I know by all your posts that it is not easy to solve this old issue, but.... Richie is Richie and nothing is lost by my 'wantwish'. Remote over lan or over internet users will be happy if Richie get a solution.
Best 73
W4WMT
Post by W4WMT »
w-u-2-o wrote: It is worth noting that this configuration does work for full-break-in QSK on Thetis/P2/Orion platforms.
Indeed!
In fact, the full-duplex QSK now available on the above platform makes old-fashioned sidetone completely passe IMO. You're just hearing yourself on the band, like a regular station. Chris and Rick did a super job on this :-)
Bryan W4WMT
EA1DAV
Post by EA1DAV »
Best 73
EDIT: I have Anan 100D
EA1DAV wrote:In my current setup the CW paddle is direct to a com port as you point, and setup, dsp,cw configured. Also in contests, I use a virtual port in the same machine to keying Thetis, so more close is imposible. I know by all your posts that it is not easy to solve this old issue
It's really not a difficult problem to solve. It just waits on someone who finds solving it interesting.
To clarify, my post is intended to support your wish
This will never work for internet (WAN) users, only LAN users.
Which makes it even more important to you, since you cannot use the full-break-in capability of Thetis with that Angelia-based radio.
There is an old school answer to this problem and it is surprising that nobody has ever posted about it: just wire an old-fashioned code practice oscillator, aka sidetone oscillator, across the output of the key or paddle
w9ac
Post by w9ac »
Discovered that the Zero Beat CAT command (ZZZB) isn't functional when the display is expanded (i.e., wide pan screen).
w9ac wrote:Discovered that the Zero Beat CAT command (ZZZB) isn't functional when the display is expanded (i.e., wide pan screen).
ran fine with spectral Xpixels as 4807. zzzb calls same code as 0beat button. It finds peak in passband, not whole display width.
w9ac
Post by w9ac »
Strange. No matter where I place the passband, ZZZB won't invoke when the display shows "Expand" at the top menu bar. Works fine when "Collapsed" is shown. ZZZB command through StreamDeck:
echo ZZZB; | ncat 127.0.0.1 13013
vk6cpu
Post by vk6cpu »
Downloaded the latest pre-release this morning, uninstalled previous version - directories gone and then installed latest pre release.
I get the following error message "requested value 'tuneDrive' was not found"
I then tried a totally clean install - by renaming data folder in Appdata
This time thetis loaded and ran but when I tried to import my old database file it again throws the same error after restart
Below is log file :-
Read <C:\Users\nhanw\AppData\Roaming\OpenHPSDR\pre rich Thetis-x64\Thetis_database_export_4-23-2022_9.06 AM.xml>
Did not import table <BandText> into database.
Imported table <BandStack2Entries> into database.
Imported table <BandStack2Filters> into database.
Imported table <BandStack2FilterFrequencies> into database.
Imported table <BandStack2FilterModes> into database.
Imported table <BandStack2FilterSubModes> into database.
Imported table <BandStack2FilterBands> into database.
Unrecognized table: BandStack2HiddenEntries
Did not import table <Memory> into database.
Did not import table <GroupList> into database.
Imported table <TXProfile> into database.
Did not import table <TXProfileDef> into database.
Imported table <State> into database.
Imported table <Options> into database.[/i][/i]
Import succeeded.
Any suggestions .. or do I just have to go through setup procedure as a new radio?
All the best
Nigel
VK6CPU
INTEL i9 12900 64.0 GB Ram
vk6cpu wrote:Downloaded the latest pre-release this morning, uninstalled previous version - directories gone and then installed latest pre release.
which version ? 2.9.0.5?
please screenshot the error msg
vk6cpu
Post by vk6cpu »
Screen shot attached
Yes latest version
https://github.com/ramdor/Thetis-2.9.0/ ... .5.x64.msi
Screenshot 2022-04-23 112646.png (52.63 KiB) Viewed 27181 times
All the best
Nigel
VK6CPU
the install process has not put the exe on there that is required. You have at one stage had the correct version, but now you do not.
1) Run Thetis and/or Thetis x64 uninstall from add/remove programs
2) go to c:\program files\openhpsdr\thetis folder and remove any existing dll's/exe's
you should also check c:\program files x86\openhpsdr\thetis if you are running the x86 (32bit) verison
3) reinstall
try again
yep, issue in existing code. It is using a function to 'click' the zbeat button which is not visible as it is on the expanded view, and hidden in collapsed. The function call 'PerformClick' does nothing when a button is hidden. Old bug.
vk6cpu wrote:Screen shot attached
Yes latest version
This is actually a bug, and I will need to re-release 2.9.0.5 by the looks of it. If anyone has had Tdrv selected as a button action this will error.
In the mean time, to get it working
1) edit your database.xml, and search for infoBar_button1
2) change <Value>Tdrv</Value> to <Value>Blobs</Value>
3) do the same for infoBar_button2
4) change <Value>Tdrv</Value> to <Value>Blobs</Value>
Sorry for this, somewhat of an oversight ! I will look at working a fix shortly.
UDPATE 2.9.0.6
A small update has been released, to fix a couple of bugs primarily. Post 1 has been updated.
https://github.com/ramdor/Thetis-2.9.0/ ... g/v2.9.0.6
vk6cpu
Post by vk6cpu »
Thanks - your latest release 2.9.0.6 solved my problem!
What great service!!
Ciao
All the best
Nigel
VK6CPU
Locked
