Page 3 of 3
Re: Firmware fix for RF appearing on RX only ports
Posted: Fri Feb 16, 2024 8:00 pm
by n1gp
Did you have a chance to try the C version?
https://www.dropbox.com/scl/fi/kzu37u2n ... bbf3a&dl=0
I'm working on another set of 4 going further back, almost back at the 12.2.1A scenario. Will post
in roughly an hour or so. Hoping to get back to a baseline that at least connects.
Posted: Fri Feb 16, 2024 8:43 pm
by wa1oxt
Rich.
Installed v_12.2.1C. Appears to have solved my issues.
Oh Joy.
Now, how did I miss that?
Was there a v 12.2.1B which I may have overlooked also?
Thanks for your help, Will keep an eye on it over the next few days and report bk.
Regards, Gary
Posted: Fri Feb 16, 2024 10:07 pm
by n1gp
Glad to hear something is working. I'm not sure how it got missed, it isn't on the github bug/issue thread
maybe up further in this one. Actually it is in my private messages on this board, DG9FDA had found seq errors
during TX with 12.2.1C.
The 12.2.1B was reported to not connect.
At any rate, let me know how it works out for you. Just in case here are 4 more that I built:
https://www.dropbox.com/scl/fi/zajs7pdc ... gha2p&dl=0
https://www.dropbox.com/scl/fi/mb9axhtp ... grwlo&dl=0
https://www.dropbox.com/scl/fi/dtvncn9f ... 49k59&dl=0
https://www.dropbox.com/scl/fi/a71quuzq ... qi046&dl=0
Posted: Sat Feb 17, 2024 12:36 am
by wa1oxt
Rich
v_12.3.3I_ Loads ok. RX/TX dropout every 2-5 sec.
v_12.3.3J_ Loads ok. RX/TX dropout 5-10sec.
v_12.3.3K_ Error Starting SDR Hardware.
v_12.3.3L_ Error Starting SDR Hardware.
I will keep the lid off for more testing this eve.
gary
Posted: Sat Feb 17, 2024 12:18 pm
by n1gp
There is another tester on a github issue thread (for Thetis) that is testing these and
getting the same results as you. You both have mentioned that if you go back to 12.1.8
things just work. So I put only the fixes for the CW/RF issue in to 12.1.8 and here are
4 images of that. I changed the version to 12.2.4:
https://www.dropbox.com/scl/fi/qseteidy ... 2we7t&dl=0
https://www.dropbox.com/scl/fi/xnkmvrpb ... cserd&dl=0
https://www.dropbox.com/scl/fi/jb0efjcr ... erf0u&dl=0
https://www.dropbox.com/scl/fi/4rpwl3ip ... hf4rm&dl=0
Posted: Sat Feb 17, 2024 12:38 pm
by wa1oxt
Rich
Open for testing after 9am today.
I will follow up then.
gary
Posted: Sat Feb 17, 2024 3:02 pm
by wa1oxt
Rich
v_ 12.2.4A
Same issue as 12.2.1A as I posted.
v_12.2.4B
Same as 12.2.1A
v_ 12,2,4C
Rx constant dropouts
v_ 12.2.4D
This one is interesting.
Rx seems stable.
APD not correcting properly.
without ADP IMD3 down 40dBm
with APD IMD3 down 34dBm
Amp View Phase off the charts, also became erratic.
Any questions are welcome.
gary
Posted: Sat Feb 17, 2024 5:30 pm
by n1gp
Were you seeing any sequence errors with the two that somewhat worked?
Just a note for those interested, these last 4 images were the exact same code used
in v12.1.8 that seems to work for most. Same Quartus v21.1 tools to build. The only
difference is a few lines that send SPI data to the PA Filter board for the CW/RF fix.
Each one was the same yet the tools build them differently each time. That is the
free version of the tools.
I'll am building some more and will post in approx 45 minutes.
Posted: Sat Feb 17, 2024 6:04 pm
by wa1oxt
Rich
No Sequence errors.
Have not had any since installed cmASIO .
Rich, if your flipping bits to the PA Filter bd (don't have one here) would that effect operation of my 300wt EB-104 PA?
gary
Posted: Sat Feb 17, 2024 6:39 pm
by n1gp
It shouldn't affect your EB-104 although I'm not that familiar with it. If you don't connect
the 10-pin SPI header to it then it shouldn't affect it.
Nice to know about no sequence errors which at least shows the network timing as
working. Here are some more images to try. Probably it for today. Thanks for your help.
https://www.dropbox.com/scl/fi/fpa1ptgj ... ezlj4&dl=0
https://www.dropbox.com/scl/fi/poxbljyz ... tr3m1&dl=0
https://www.dropbox.com/scl/fi/fuo8dde6 ... 9rifn&dl=0
https://www.dropbox.com/scl/fi/oukveoht ... mq1nx&dl=0
Posted: Sat Feb 17, 2024 9:05 pm
by wa1oxt
Rich
v_12.2.4E
RX appears stable.
ADP/Amp View erratic.
v_12.2.4F
RX appears stable.
APD/Amp View very erratic.
v_12.2.4G
Rx appears stable.
Very few Xmit drop outs while using APD.
APD works really well!
Overall, this one is promising.
v_12.2.4H
This one is really interesting... needs more testing.
Rx appears stable.
No dropouts observed while using APD.
Not sure what you did
Both 12.2.4 G & F produced the best APD /Amp View results I have seen in a long time.
Very fast recovery and clean.
Great job.
Tnx
gary
Posted: Sat Feb 17, 2024 9:14 pm
by n1gp
Gary, did you mean "Both 12.2.4 G & F produced the best APD /Amp View results..."
or "Both 12.2.4 G & H produced the best APD /Amp View results..." ? I think you meant
the latter.
In F, G, and H I made sure that the 122.88MHz clock was the same, not buffered through
other chips, going to the TX DSP and DAC, 3 places.
Tnx agn for all the testing you have done.
Posted: Sat Feb 17, 2024 9:56 pm
by wa1oxt
Rich.
Correct G&H best.
Great Job Rich.
Giong to start running Thetis in RealTime.
Want to see how stable my system is.
Glad to help.
tnx again.
enjoy..
gary
Posted: Wed Feb 21, 2024 6:22 pm
by dl2hbj
n1gp wrote:It shouldn't affect your EB-104 although I'm not that familiar with it. If you don't connect
Today I had the time to test the new versions 12.2.4E to H. Fortunately, I could assume that it can be programmed with the HPSDRProgrammer_web.exe, because Garry already reported that they connect to Angelina. This saves a lot of time compared to the "normal" programmer, where the jumper has to be changed all the time. I would probably have to install a switch for this...
Here's what I've noticed:
12.2.4E:
- Connecting to Angelia
- RX seems to be fine, no sequence errors
- TX distorted, no modulation, no 2-tone
- no ADC2 overload
12.2.4F:
- TX distorted, modulation distorted, 2-tone working
- PS-A not correcting
- no ADC2 overload
12.2.4G:
- TX seems to be fine, 2-tone working
- no ADC2 overload
12.2.4H:
- no ADC2 overload
For comparison purposes bk to 12.1.8
- connceting to Angelia
- RX fine, sometimes sequence errors
- TX fine, 2-Tone fine
- PS-A correcting
- regularly ADC2 overload
I hope it helps.
Thanks for your efforts, Rich and Garry!
Posted: Mon Mar 18, 2024 5:19 pm
by Gary_Sitton
I have an early Anan 7000DLE (s# 13), so which firmware update do I use?
Posted: Mon Mar 18, 2024 5:22 pm
Gary_Sitton wrote:I have an early Anan 7000DLE (s# 13), so which firmware update do I use?
Go back to the first post in this topic. You use the one for "ANAN-7000/8000 MkI/II EP4CGX150F896 Cyclone IV series FPGA"
Posted: Sat Apr 13, 2024 8:10 am
by Alexander UC
This problem occurs not only for relays ANT1,2,3. But also for relay rx 2 in. this relay does not have time to turn off the second receiver. The delay is 15-20 ms. In cases of closely spaced antennas, this may lead to malfunction of the second receiver! When selecting the qsk mode, the rx 2 in relay does not work at all!
Solution to the problem with relay delay Ant1,2,3, rx 2 in: Set the value cw delay, Key-Down = 35ms. It seems it should be responsible for the shape of the signal. But the form does not change. Don't turn on the qsk mode!
Posted: Tue Apr 16, 2024 1:19 am
by KA1GXR
Hooray:
Rf on rx port fried my magnetic loop amp years ago. Verified it with Doug at the time. Updated firmware and new Version Thetis dev2 . Can no longer see any rf on rx only port. Updated my 200D and 8000dle. No new issues found so far. Pure signal and diversity good.
Great work on the firmware and Thetis.
Tom
KA1GXR
Posted: Wed May 22, 2024 5:26 pm
by JJ4SDR
Apologies for redundancy as I posted this response to Norbert - DL8LAQ - in the main Thetis forum. Wanted to repost here.
Below, see the software and P2 versions I am using with my ANAN 7000 DLE MKII (it has the EP4CGX150F896 Cyclone IV series FPGA)
Thetis v2.10.4.3 x64
Protocol 2 v2.1.18
If I understand correctly, RF appearing on a Receive only antenna ports (in my case, I receive only on Port 1 and I do not transmit on ports 2 and 3, only port 1) is more of a problem if you have a separate Receive antenna connected to port 2 and/or 3, correct? Also, the hot-switching is more an issue for CW mode, correct? I have only Port 1 connected to an antenna.
Sanity check: Even without a separate receive antenna connected to either port 2 and/or port 3 there is likely the TINIEST of RF appearing on those ports, but for all intents and purposes, that RF will not pose a threat to the ANAN, right? :) So, consequently, I don't need to install a "fix" I would think.
73 de Juha
Posted: Wed May 22, 2024 6:40 pm
by JJ4SDR
Richie's comment at https://github.com/ramdor/Thetis/issues/228 on Oct 24,2023 and, particularly, where he states "This only happens in CW mode as the internal TRX clack back and forth with semi break in delays of approx 250 ms" is huge!
As others have pointed out, I really should update to a much improved Protocol 2 firmware version as I am on CW quite a bit, including in big CW contests, once or twice a year. I have operated for several hours (12-16 hours or so) in contests, but had not experienced any hot switching issues with my Solid State amp although my RF, PTT and MOX delay times were very low (I am using these on SSB too). Same with key-up and key-down times.
Can anyone of you CW operators provide screen-shots of your delay times? I already have some from W9AC although he has done hardware mods that no doubt help him "get away" with much shorter delays than I would.
Below, see my current numbers.
General Options1 settings.jpg (152.43 KiB) Viewed 29595 times
Perhaps I need to tweak these numbers?
Best,
Posted: Mon Jun 30, 2025 6:01 am
by rainbow
is it possible to get the patch/diff for the 100D?
