Hermes F3, wrong part...
I received this email from someone who asked me to post it for them, as they are a bit shy about doing it themselves. I don't have an ANAN-10 and therefore can't report on any instability, however his findings are certainly very interesting--73, Scott
Just a heads up. I finally tracked down a hardware instability in my ANAN-10 (TAPR Hermes board/APACHE 10W PA/Case). Symptom: random crash after prolonged period of operation. It seems that the Thermal re-settable "fuse" F3 on the Hermes board is the wrong value. The schematic shows a 2A "fuse". The BOM indicates a part# of MF-MSMF110/16-2CT-ND (indicated as a Bel Fuse part but actually Bourns). The measured current in F3 is ~1.6 amps. The part is spec-ed at Ihold=1.1A and Itrip=2.2A. The part is operating in its transition zone!
They seemed to have chosen it for its trip point and didn't look at its hold rating. My thermal camera shows it running at ~90C! Not good.
I replaced it with a 2A hold part and all is good.
This is just some info that you may want to keep in the back of your mind, if anyone is experiencing random issues with their ANAN-10.
fmsmf-772347.pdf
(440.28 KiB) Downloaded 1128 times
jsm
Re: Hermes F3, wrong part...
Post by jsm »
The problem is that there is no 2A hold part with the same itrip value (probably not possible). The 2A hold part has a 4A trip. So that part may run cooler and work great, but it also may not be providing the needed protection. In the HPSDR email list Phil Harman mentioned that he replaced F3 with a wire jumper. The question is whether the suggested replacement part is actually any better than a piece of wire, i.e. will it trip and protect the circuitry it is supposed to protect, or will the damage be done before it trips, therefore behaving no better than a piece of wire.
John
AC0ZG
K3IT
Post by K3IT »
I used PTS18126V300 fuse for F3 (3A hold, 5A trip). LT3680 datasheet seems to indicate that it should deliver 3.5A output, good enough to handle PHY 1Gbps 500 ma increase on the 5v rail? May be I'm overlooking something..
LU2FAF
Post by LU2FAF »
any update about this ?
im using an orion mk2 , it seems mine fails when overheat
LU2FAF wrote:any update about this ?
That's because the firmware build you are using fails to make timing on your hardware when the FPGA temperature increases. It has nothing to do with current overload of resettable fuses on Hermes or Angelia boards. Try a different version of the firmware.
Additional info from Kjell, especially for Protocol 2 folks...
'Kjell Karlsen' la2ni@online.no
When the problem with Hermes not working good on Protocol 2, I tested my 3 Hermes boards and in addition to the fuse problem I also discovered that the 3,3V coming from U23 and goes to U19 (AVDDH), had a voltage drop on the input of U19 and U13, the Ethernet switch. For me it seemed to be too thin lead in the PCB so I just connected a thicker wire directly between U23 and U19. Both the 3,3V and 1,2V on U13 increased. After that 2 of my 3 Hermes boards works fine on protocol 2 up to 484 KHz sampling rate and the 3.rd also works OK on 768 KHz.
GW0DQW
Anyone in UK done the fuse update on Anan 100 ?
Post by GW0DQW »
Hello there ,
Name is Chris in South Wales and I was wondering if any user in the UK has done the firmware update to use Thetis .
I have the Rev24 version , with built in Pure Signal and firmware switch fitted underneath.
I am looking for guidance on what and how to go on on the hardware up grade and firmware upgrade .
Am i right in thinking that in my case there is only one fuse to be upgraded .
Appreciate any help or tops please
73 Chris GW0DQW
Chris,
Fuse info in this topic where I moved your post to.
P2 firmware update discussions are separate and are taking place here:
https://apache-labs.com/community/viewforum.php?f=32
