LCD Arduino Code
Simon
LCD Arduino Code
Post by Simon »
If I haven't missed this - we need somewhere for the LCD/Arduino releases. There was talk on Team Speak that Warren (?) had done something.
sdr-radio.com
Re: LCD Arduino Code
Hi Simon,
Links to all of the firmware, including the LCD microcontroller code, are here: https://apache-labs.com/community/viewt ... =18&t=2334.
The directions, which may not be complete, are in the 8000 user guide. Links to all of the users guides are here: https://apache-labs.com/community/viewt ... =35&t=2340
However, I guess I need to make these easier to find. I'm am going to update the global sticky post "Useful Websites) to include these links as well.
DL8LAQ
Post by DL8LAQ »
I just finished update of firmware (v1.6) and front panel LCD software (1.6b).
73, Norbert
Simon
Post by Simon »
w-u-2-o wrote:Hi Simon,
Thanks - installed. Shame we have lost the numeric Fwd / Ref values :( .
sdr-radio.com
Re: LCD Arduino Setup on pc
Post by Joe »
I used the instructions listed in the 8000 manual but for some reason my lcd code will not compile in the step listed to “verify compilation”? Everything else went as planned. I know the Arduino software version is the latest. Any help or direction is much appreciated.
73’s
It's hard to say, Joe, there are a lot of things that could go wrong. It's been a very long while since I messed with this so my memory is not good. However it seems that most people run afoul of including the liquidcrystal440.zip library file properly. Do not unzip it. After opening the sketch for the LCD, make sure you can see LiquidCrystal440 under Contributed Libraries when you go to the Sketch > Include Library menu. If you don't, then pick on Sketch > Include Library > Add .ZIP Library and point it at the correct zip file.
Also, the board should be set to the Nano, if I remember correctly.
Post by Joe »
Thanks Scott
I will check these steps.
Post by Joe »
I did get things to compile fine but could not get the sketch to upload. After searching I found that you have to use the ATmega328 (old bootloader) designation for the processor under the "Tools" menu. All works great now. I was testing the new port that I installed on the rear panel which now allows me the ability to load new Arduino changes without removing covers, etc.
Thanks and 73's
W4WMT
Post by W4WMT »
Is there a way to just turn off the LCD/Arduino stuff and run without it?
Bryan W4WMT wrote:Is there a way to just turn off the LCD/Arduino stuff and run without it?
Hi Bryan,
There is no straightforward way. Do you have the schematics? It's probably possible to wire around a number of things: PTT disable, 50V power control, buzzer, etc. However, it's probably easier, especially since you are familiar with software, to simply wire around these things in the Arduino sketch code. For example, you could change the sketch to not alarm on high VSWR, or just change the VSWR limit to something higher, etc. That's usually the problem most complained about, I think.
Docfin
Post by Docfin »
The link for the ver 1.6 LCD firmware for the 8000dle does not work.
Dows anybody have the V1.6 firmware or can somebody fix the broken link or provide a new working link?
Thank you.
DH1KLM
Post by DH1KLM »
Thank you, Sigi!
That is a terrible place for it. It should be in it's own repository since it is not part of PowerSDR. When I get a chance this week I will move it to the top level in the TAPR hierarchy and post an updated link.
@Docfin - it's generally considered bad forum etiquette to start sending PM's because people did not answer your question right away ;)
DH1KLM
Post by DH1KLM »
Hi Scott, yes, it really is a terrible place.
I found it a long time ago, back in the PowerSDR days, while looking for the 8000 LCD ino file.
Moving the repository is a good idea.
I finally did get around to pushing this to the top level of the TAPR repo's: https://github.com/TAPR/OpenHPSDR-8000DLE_LCD_Firmware
