CuSDR64 v0.3.3.0 (Feb 2017 Release)
I'm wondering how many ANAN users have played around with Hermann's (DL3HVH) latest v.0.3.3.0 release of CuSDR64 that came out in Feb of 2017?
It doesn't look like there were a lot of visible changes but it does run beautifully and is a treat to look at. I made a brief video of some of the menu forms that are used to set the network parameters and also a few operating settings as well. There really isn't an install program, you simply unzip the contents of the downloaded zip archive into an appropriate folder you make in the Program Files directory where 64-bit programs reside in Windows.
A file named "settings.ini" will be created the first time you run CuSDR and that is where you can edit a few things that are not yet hooked into the user interface. As an example, for this video I edited the settings.ini file to set the tuning step for Receiver 0 to 10kHz to accommodate quick tuning across the AM broadcast band. To access the RX-0 controls, right-click on the panadapter and all the controls will appear in an un-docked menu that auto-disappears when your mouse moves off of it, unless you click on "Lock" in the upper right corner of the floating menu. You can also click on the "Radio Ctrl" button in the upper left area of the main user GUI to open up a docked menu area on the right side of the GUI.
Note that some users have found that CuSDR does not produce audio through their computer speakers. I never really noticed this since I have always run an audio patch cord from my ANAN's front panel headphone jack to the line-in port of my computer's soundcard. This assures that whatever software I am running with the ANAN will always port the audio to the computer's sound system. This also guarantees that any recording software I use will have the ANAN's audio available to it without using VAC or other interfacing software. If I want to listen to the ANAN with headphones I plug them into the Computer system's Bose Companion Speaker headphone jack. The fidelity is beautiful with this setup and I have yet to find any drawbacks to this configuration.
You can download CuSDR (cusdr3.zip) at this link: https://github.com/hvh/cusdr3/releases
Apologies for the continuous static crashes in the video. We had quite a storm come through the area today!
WB8LBZ
Re: CuSDR64 v0.3.3.0 (Feb 2017 Release)
Post by WB8LBZ »
Thanks for the mention, I have given this and a few others a glance from your information page. I haven't got my computer assembled yet and my main machine is too unstable.
Larry, WB8LBZ
El Paso, TX
good in QRZ
marc
Post by marc »
Hi Rob
Totally agreed. It's a really nice interface once you have found how to deal with "right click" parameters.
The lacks of audio processing is indeed a major problem (unable to demodulate any signal with my Hermes Lite). I hope this feature will be soon added to the project.
Pluging a cable between the "audio output" of the hermes and the soundcard of the computer is indeed a very smart idea and could be an efficient temporary solution.
But from a pure "signal path" perspective, you should admit it's a nonsense... the ADC delivers a already "audio spectrum shaped" signal (a major misconception, but it's an HPSDR legacy limitation). This signal is then forwarded to the computer for demodulation, filtering etc, and sent back to the rig to pass thru the codec.... and then routed back again to the computer. And you'll only be able to use this signal for old style analog voice transmissions. No VAC redirection, Only basic SSB. Frustrating isn't it ? :- ))
hope CuSDR 4 will be out soon
Marc
I've had a play and indeed its a very good looking interface.
I don't know what forms the underlying code for CuSDR, but it always makes me sad to see such fantastic work done outside the context of PowerSDR mRX or Thetis. There is already everything one could want in there, it lacks only a modern UI and a split into client/server pieces to take it to the next level.
Indeed, with the re-architecting/refactoring that went on in Thetis, 95% of what is necessary for a radio server now resides in the channelmaster.dll. If all that fantastic effort that is being put into reinventing the entire wheel was put into just the UI imagine what might be. With a little bit of a shell around channelmaster.dll there could be an openHPSDR server app with all of the power of PowerSDR mRX/Thetis. That includes PureSignal, NR2 and squelch (both the best in the business), low latency filtering, you name it. All of the things nobody ever puts into the alternative clients. Move the audio mixing functions to the server side as well so that thin clients only need to receive a single audio stream. Then take that awesome UI work, put a client shell around it and merely have it interface to the channelmaster.dll based server app.
Bottom line: keep the fabulous UIs and extend them to control all the functions of channelmaster.dll, keep channelmaster.dll, build the client/server wrappers, move the audio handling into server wrapper. End result: awesomeness!
DL1OF
Post by DL1OF »
Rob,
thank You for the hint! Didn't know Herman had released a new version.. It's a beauty! Although i like what i have i wish all the developers could work on this sw to bring it to a final package! But i know that's not possible. These are two different pair of shoes. It's an old saying here in Germany btw.
It would be a huge benefit to have a fully outfitted sw for Linux in the future as well. I mean outfitted with everything like PureSignal, and all the great features of WDSP!
Rob, You don't have to edit "settings.ini" to change the tuning steps. Just click on the associated digit on the frequency readout to choose the tuning step You like! By clicking twice You even can have a step which is five times the value You click on.
Bernhard , DL1OF !
Marc, your comments about the convoluted audio path made me laugh. It does seem silly doesn't it? Scott, your comments about the UI made my eyes go wide with all the possibilities. I definitely do understand that at this time the focus is on function rather than form, but at some future date things will reach a point where tinkering begins with the UI. In fact, the recent work Doug has done with the metering in OpenHPSDR is very impressive. I have played around with all kinds of PowerSDR variations and have to admit that the S-Meter in the Genesis (GSDR) version is pretty impressive. You can create your own scale in JPG format with simple photo editing software and stick it into the Console folder to make your own custom meter. This one was made by a friend of mine, Jeff - W2NBC and it's the best I have seen so far.
This is one I made for use with a skin that uses a National NC-155 theme. I excluded all the transmit functions because I only use GSDR with the little Fichten Field Day SDR receiver.
After the functionality of the software reaches the top shelf (it's getting there pretty fast right now) I would love an interface that allows a lot of user customization.
Bernhard! Thank you for that tuning step tip! It works great! I need to click around more!!!
WB8LBZ
Post by WB8LBZ »
I gave the latest download a try. The radio setup didn't show a 8000. It looks good on my hardware. It also has the German 40 Meter allocation not the US. Maybe I missed a setting.
Larry, WB8LBZ
El Paso, TX
good in QRZ
laserbill
Post by laserbill »
I am looking for a link to download the current version of CuSDR 32 or 64 bit
Seems all the links are all 404 dead links. I have googled and no joy
Can anyone point me to a working link?
All the best 73
Bill
G6SVN
Hi Bill,
As you said, it looks like the download links leading to the compiled versions of the V3 release are no longer good. I'm not sure what the exact status of the CuSDR project is at this time. Guess we will have to hold onto to the hope that V3 will reappear or that it will continue to be developed for a new release. Sorry that I have no information for you.
laserbill
Post by laserbill »
Hi Rob,
Thanks for the quick reply, seems a shame as the program looks great.
Best wishes
Bill
G6SVN
n1gp
Post by n1gp »
If anyone has a Linux development system that you can build QT applications on,
I've got a version that I modified adding local sound (alsa) and the capability to run
up to 20 receiver slices (used for testing firmware) up on github:
https://github.com/n1gp/cudaSDR
73's
-Rick / N1GP
Rick,
That's an impressive demonstration of more multiple receivers than I ever imagined I'd see with one chunk of consumer hardware!
I agree very impressive Rick, it really is a great looking interface.
n1gp
Post by n1gp »
I've actually had 20 running, albeit a bit taxing on the Intel I7 CPU.
I only added the sound and extra receivers, the impressive interface is all Hermanns (DL3HVH).
OZ1CT-Ben
Post by OZ1CT-Ben »
where to find a download link that works for CuSDR ????
n1gp
Post by n1gp »
Here's some pre-3.3.0 Windows versions:
https://github.com/TAPR/OpenHPSDR-SVN/t ... VH/archive
73's
-Rick / N1GP
dl3hvh
Post by dl3hvh »
n1gp wrote:If anyone has a Linux development system that you can build QT applications on,
73's
-Rick / N1GP
Hi Rick,
this is very impressive! I never tried 20 receivers, but it seems that the soft realtime implementation with Qt's threads really does a great job.
If I will ever come back to coding (cuSDR), I will take a deep look at Warren's channelmaster, probably doing a Qt implementation of his ideas (I started on that when I was still active).
And for the GUI I still have lots of ideas how to improve things!
Best wishes,
Hermann DL3HVH
DL8LAQ
Post by DL8LAQ »
Best wishes,
Hermann DL3HVH
Hi Hermann,
nice to see you here!
Maybe you can share some of your ideas with Richie? Thetis is getting better and stable almost every week, but still lacks of real improvements of the GUI. Richie is on the right way I think :-)
Edit: Added the missing word "way" :-)
73 and "guten Rutsch", Norbert
I was thinking the same Norbert :)
PD3LK
Post by PD3LK »
Anyone suceeded to run CuSDR64 with his/hers Anan 7000?
Does it work with protocol 2?
Leon,
It should run fine with your 7000 but it will only work with protocol 1 firmware.
PD3LK
Post by PD3LK »
Thanks Rob! that explains why it won't run here, it can't find the right IP address for example.
I give up cos i need protocol 2 for Thetis and SDR-Console.
Return to “All Other Clients”
