Thetis Firmware
skipph
Thetis Firmware
Post by skipph »
Wondering what firmware to run with the 100D and where would I get the firmware download from? Tnx, Skip
John-G0ORX
Re: Thetis Firmware
Post by John-G0ORX »
Look in https://github.com/TAPR/OpenHPSDR-Firmw ... ANAN-100D)
The latest version 1.6 end file is in there.
-- John g0orx/n6lyt
John-G0ORX
Re: Thetis Firmware
end ... rbf
skipph
Re: Thetis Firmware
Post by skipph »
Link does not seem to be working. Also, do I need a different version of bootloader or programmer? Tnx, Skip
Re: Thetis Firmware
You have to use new protocol (Protocol 2, or "P2") firmware to run Thetis on any radio.
P2 firmware for all radios can be found here.
All P2 firmware is late alpha/very early beta status. It may work, it may not work, or it may sort of work. If you've loaded it and nothing is working, switch back to P1 firmware and make sure all is well. If it is, it might not be working on your particular radio. Because of timing problems in the currently released alpha/beta P2 firmware, it is, for example, possible to try the same firmware on ten different 100D radios and watch it work on some and not on others.
When moving from P1 firmware to P2, you can use either HPSDR Programmer or HPSDR Bootloader.
When moving from P2 to P1, or from P2 to a newer version of P2, you can use either the new protocol programmer or HPSDR Bootloader. I recommend Bootloader, it is easier and more reliable.
Instructions for using HPSDR Programmer and HPSDR Bootloader can be found here.
