N1MM+ Spectrum Monitor
WA8KHP
Post by WA8KHP »
Is it possible for OpenHPSDR MRX or Thetis to work with the latest improvements of N1MM+ using the Spectrum Display Window?
Here is the documentation on the Spectrum Window:
http://n1mm.hamdocs.com/tiki-index.php? ... ay+Window/
David - WA8KHP
David - WA8KHP
Re: N1MM+ Spectrum Monitor
Dave,
I do not believe that PowerSDR mRX, or Thetis, has the ability to feed the appropriate data to N1MM+ for that purpose.
Thetis does display spotting in the panadapter, but only from a single spotting source.
If you want/need multiple spotting sources simultaneously, I believe that SpotCollector is your only choice.
If you are willing to live on the bleeding edge of alpha firmware and beta software, you could run the new Protocol 2 firmware in your radio and Thetis on your PC, get spotting in the panadapter from one spotting source, and supplement that with SpotCollector in the normal fashion.
