ANAN-100 issues
K2CB
ANAN-100 issues
Post by K2CB »
Using an ANAN-100 (Hermes) FW 3.2 with V3.4.2
All was working well last weekend. Turned the radio on today, started up PowerSDR MRX V3.4.2, and the receiver was as if no antenna was connected. Verified all antenna connections.
Clicked the ON/OFF button in MRX to turn the radio off, then on, and the receiver appeared to come to life. Then I decided to try and tune around 20m with the mouse. While the frequency appears to change, the radio itself stayed tuned to the same frequency. The signals on the panadapter stayed put, and did not move left to right. However, if I enable CTUN, then the actual radio will change frequency and track the software, and the panadapter will indicate accordingly.
Next issue, the radio will not transmit. If I hit the mic ptt, or MOX tab, or even the TUNE tab, the panadapter changes color to the color set for transmit in the database, but I still see the receiver activity in the panadapter, as if in full duplex mode, but no transmit signal indication whatsoever. Nor do I hear any of the tx related relays click inside the radio itself.
Finally, if I try to change bands, the radio appears to stay on the same band hardware-wise. For example, if I am listening to 14.250 USB, then change the band to 80m, the radio is still receiving the same 20m signals. However, while changed to 80m, if I hit the ON/OFF button in MRX, to do a virtual power cycle of the software, when it comes back on, the radio hardware immediately switches to the displayed 80m frequency.
Its as if the radio is not responding to some commands, but responds to others.
I tried to reload the firmware twice, and both times it seems to load ok. PowerSDR is reporting the correct firmware version as loaded.
Very strange. Any ideas or suggestions as what to try next?
Eric
K2CB
Re: ANAN-100 issues
Hi Eric, perhaps try backing up your current power sdr database and then re install power sdr and see if it works before re importing your database . Did this myself just a few days ago to cure a strange error message.
Re: ANAN-100 issues
Export your current database for posterity, then reset your database.
Assuming this works, if it becomes a recurring problem look for some sort of file system corruption on your PC.
K2CB
Re: ANAN-100 issues
Post by K2CB »
I tried resetting the database a few times. I also went and tried OpenHPSDR on a second computer. Same results.
Re: ANAN-100 issues
It's starting to sound like a broken radio, except for the "it won't tune" part, that part sounds like a software/firmware/database problem.
K2CB
Re: ANAN-100 issues
Post by K2CB »
I found the problem.
Someone in my household decided to turn on their Amazon Kindle after a long period of storage. As Murphy’s Law would have it, they decided to turn the darn thing back on the morning of the day I decided to use the radio.
When the Kindle came up on the Wi-Fi, it landed on the same IP address which was previously assigned to the ANAN-100.
I used the boot loader utility and assigned a new IP address to the ANAN-100, in the reserved non-dhcp range, and now the radio works just fine again.
Strange that neither device reported an IP conflict. Even more strange that certain functions worked, and others did not.
Why couldn’t I have thought to check the “connected devices” earlier?
Hopefully this post saves someone else from the same headache in the future!
Eric
K2CB
Re: ANAN-100 issues
This is why it pays to have everything use DHCP to the maximum extent possible.
You can only get into this situation if one or more of the devices has a fixed IP. Which one(s) had a fixed IP when the problem occurred: the Kindle, the radio, or both?
Re: ANAN-100 issues
I've been following the thread Eric and scratching my head because the behavior of the rig was so strange. Thanks for posting the explanation of what was going on. As you said, very strange that the conflict was not reported by the OS or one of the devices, but good for you for sorting it out!
K2CB
Re: ANAN-100 issues
Post by K2CB »
Scott - the radio had the fixed IP address.
Rob - since the Windows PC’s IP address was actually ok, the OS would not have reported any issue.
OpenHPSDR itself did not report any conflict when talking to the radio.
The Kindle wasn’t even in use. It was just sitting on a desk, but it too did not report any IP conflict issue.
Since I had limited control of the radio, an IP conflict as the last thing I suspected. Only hours after I disconnected the radio and packed it for shipment, did I get the idea to check the router and assigned IP addresses.
Eric
K2CB
Paco
Re: ANAN-100 issues
Post by Paco »
Where can I buy the power switch for an ANAN-100.
Thank you
Paco
