Thanks for the look, Clay, it looks pretty good!
Too bad they chose to use a -60dB coupling factor. This puts the feedback level at about +2dBm at 1500W. That will work, certainly, but is not optimum, which is more like +7dBm. And it becomes less optimum as power is reduced. IMHO, it would be better if amp suppliers shoot for +10dBm outputs at 1500W (-50dB coupling factor), then people can fine tune the last few dB to taste with a rotary step attenuator:
They are usually cheap and plentiful on eBay.
