ANAN 7000 DLE / Orion MK II J16 Pinout
dl4zbg
Post by dl4zbg »
in order to get Line Out signals from the breakout board, I was searching for the Orion MK II I/O Pinout (J16? 26 pins?).
Unfortunately, I was not able to find something.... Does somebody have any information regarding this topic?
Volker
DL4ZBG
Re: ANAN 7000 DLE / Orion MK II J16 Pinout
Volker,
Sorry for the delay in responding.
The J16 pinout on the 8000 and 7000 is identical to that on the 100D and 200D with one exception: on 8000's after Dec. 2017 and 7000's, Pin 10 is not ground, it is "BUFF_OUT" (function currently unconfirmed, my guess is it is for implementing EER amplifiers).
Simply go look at the Angelia or Orion schematic and you will be all set (except for Pin 10).
dl4zbg
Post by dl4zbg »
Thank you Scott,
I really appreciate your help. I checked all used (known) pins with an ohm meter.
Volker
