No audio on headphones
All of a sudden I started getting really lousy signals on WSJT-X with my ANAN 100. Fat signals and unable to decode.
I now find there is also no audio coming out the headphones...so though that might be related.
Putting a known signal on the antenna shows clean on the scope but is far too wide on the WSJT-X display.
Any ideas? I've reset the PowerSDR database, reloaded the firmware, and still no joy.
de Mike W9MDB
Re: No audio on headphones
Going to need more data. Maybe some screen shots.
Headphones working OK....helps when you use the right plug....
Using an XG3 -73dBm 50uV signal into my TenTec Omni VII get this
Same signal into ANAN 100 looks good in the scope
But not in WSJT-X
de Mike W9MDB
You probably have a sample rate mismatch somewhere. Take a look the VAC tutorial.
Also, be sure you are using DIGU and not USB. This removes all receive audio processing automatically.
