Voicemeeter Potato is coming! <--not a joke!
Seriously, "Potato" is on the way! From the VB Audio Facebook page:
Re: Voicemeeter Potato is coming! <--not a joke!
Hi Scott, I'm not seeing that on the facebook page , I wonder was it deleted? Looks pretty horrible :)
It's like 20 or 30 posts down by now. Just search the page for "potato".
I'm sure it will have the same colorization as Banana when released.
Ah yes I see it now thanks. Nothing is jumping out as being any great advantage over banana but of course I'm no expert on this.
The biggest advantage will be the addition of the third virtual channel. That will allow VAC1 to be attached to the first virtual channel, VAC2 to the second channel, and any number of digital mode programs to the third. Four would actually be better, so that one digi mode program could monitor VAC1 and a second VAC2. Microphone and speakers/headphones will continue on one or more of the hardware channels, of course.
Conrad_PA5Y
Post by Conrad_PA5Y »
Yes Scott lets start lobbying for a 4th channel, it would certainly help me with the Xpol setup. Thanks for the heads up.
Conrad
W4WT
Post by W4WT »
Not being an expert in this area, does this mean we will be able to attach VAC2 to the second channel and use the UMC ASIO driver for VAC2 along with VAC1? That would be nice as that should get rid of the delay problem having to use Windows drivers for VAC2.
Joe W4WT
Conrad_PA5Y
No Joe, you can only have one ASIO driver at a time, that is still a limitation of PowerSDR mrX PS.
W4WT
Post by W4WT »
Hi Conrad,
Thanks for the info. I was hopeful but I guess not yet.
Joe W4WT
