Snap Crackle, Pop on Phone Monitor...
Bill in Georgia
8000 with Headphone plugged direct in to front panel Headphone monitor...
Upon SSB key-down, you can hear an intermittent Snap/Crackle...under the TX audio... noise does not trail audio, stop talking and it will pop/snap, etc...However the noise is not being transmitted... but it's a nuisance.
Computer is a I7 - 4790, 16GB, 32 bit, MB is a MSI Z97, SSD 450 MB. Sub Score is 7.9 ...computer is solo for Anan SDR .. other than security....
Idea's??
Bill in Georgia ... KC4PE
Idea's??
Re: Snap Crackle, Pop on Phone Monitor...
Did it ever work right, or has it always been this way?
Bill in Georgia
Radio was bought in August 2017...problem did not start up till mid Jan 2018..
W1FYI told me he had the same problem on his 200D ... Went on to say he thought WA0VY was having a similar problem and thought it was computer related??
Are you able to test VAC audio? If you can do that then you can help rule out a hardware problem vs. a software/OS problem.
SA3ATF
I have also had this phenomenon on my 200D Rev24, but after a database reset, it has been good again.
FWIW, I did not have the exact same problem, at least as far as I understand it. I had the usual audio pops and drops in VAC which was more-or-less fully resolved when I did a new computer build. The subsequent updates to the HPSDR software resolved every remnant of the issue.Bill in Georgia wrote: ... Went on to say he thought WA0VY was having a similar problem and thought it was computer related??
73 Brent WA0VY
Bill in Georgia
Not running VAC1 or 2, just using a DAW/Primary Audio ... Got 2 P-emails suggesting that I play with the Buffer settings..??
Bill, if you can use VAC, say with a simple USB headset, to confirm or deny the problem occurs with VAC, that would a helpful and scientific way of determining whether this is a software/OS problem or a hardware problem in the radio.Bill in Georgia wrote:Not running VAC1 or 2, just using a DAW/Primary Audio ... Got 2 P-emails suggesting that I play with the Buffer settings..??
Failing that, the only buffer setting that really matters when using the radio audio interfaces is the Primary Buffer setting in Settings > Audio > Primary.
See also this thread.
Bill in Georgia
From a starting point of 512 Buffers/192,000 sample rate, ran a series of different settings...No help..
If you bring up SCOPE and key the mike, you can see the pops/cracks etc.....
Went and checked all the Microphone settings ..nothing is close to "0" most ranges are in the -3 to -6 area.
Changed Databases...Did a new Database...
Do not think it's in the DAW, Cubase 5......Ican monitor the input audio feed into the 8000 and it's clean....
Will wire up a hand mike and run mike/8000/ & monitor off the headphone jack to see if we have..??
Oops just saw Scotts thread above..
Bill in Georgia
Fixed....installed a fresh copy of Windows 7 Professional...removed two boards that were baggage...a 6 out USB board and a com port board...
Now all is well....
Thanks Guys...
Now all is well....
Thanks Guys...
