PowerSDR mRX PS v3.4.9 Released
PowerSDR mRX PS v3.4.9 has been released.
This fixes the manual frequency entry bug.
Latest releases: https://github.com/TAPR/OpenHPSDR-PowerSDR/releases
Release notes: https://github.com/TAPR/OpenHPSDR-PowerSDR
ULTIMAX
Re: PowerSDR mRX PS v3.4.9 Released
Post by ULTIMAX »
Hello, I would like to report a few things I notice on the new software, when using the RX2 in the expand view, the waterfall from the top slice goes over the 2nd receiver slice below, also when using the one receiver after TX PTT disengage their is a few seconds delay for the panadapter to return to flat , I appreciated if some one can look into this, I always like the screen mode better than the original but because of this issues is useless, Thank you Team for all you do 73's. N3YV
Thanks for pointing out the RX2 display bug in collapse display mode.
The time it takes for the waterfall and panadapter to settle down wholly depends on your panadapter and waterfall settings, as well as the DUP setting.
spinomaly
Post by spinomaly »
Hi Albert,
Can you post a graphic of what you see as well as your exported database? I have not been able to duplicate the issue.
Dr. Loren Betts
W6VH
