ANAN-7000DLE/Ten Tec Hercules Amp
KL4QG
Post by KL4QG »
Going buy 100D or 200D used or new ANAN-7000DLE
I’m using Hercules Ampifier with my Icom 746pro
Very Clean sounding Ampifier
Can I use Hercules Amp with Anans
Now with Ampifier and Icom RCA plug on VOX key amp to RCA plug to Send on Icom
Can Heil PR 781 Mic Be used on Anans
Re: ANAN-7000DLE/Ten Tec Hercules Amp
If it's a Ten-Tec Hercules II, you should be able to simply go PTT Out to Key In, nothing special required.
You can use any microphone with any Apache Labs radio, with an appropriate cable, of course. Dynamic microphones generally require the 20dB mic boost option be turned on in Setup > Transmit.
Rankharris
Post by Rankharris »
I am using a PR-781 with 7000 and it works perfectly. The main point is that you need to adjust it with the equalizer to get it to fit your voice. The Heil adapter is sold by Gigaparts for the Apache Labs radios, or you can make one for yourself.
Randy Harris W4HCR
KL4QG
Post by KL4QG »
Thanks all for input it’s easy setup than to use Ten Tec Ampifier and Pr 781 Heil Mic
I just love my Hercules amp and 781 Mic
I now need find a good small computer that’s not going break bank to use on my navigation station on my 42 foot sailboat
Our old Computer finally bit dust
I’m away from Sitka AK for two weeks working
Look for me on Ak. ET 7093 ssb 8pm Ak time
