WSJT-x and ANAN10E
mark1161
WSJT-x and ANAN10E
Post by mark1161 »
Good Morning All,
I know this can be a rabbit hole when talking about two software systems playing nicely. But, on the chance that someone may have the same issue, I will explain. I use WSJT-x, (v 1.9) both with my ANAN 100D and ANAN 10E. The 100D performance is nominal and there are no issues. However, the 10E's problem is that everytime I go to TX, the mode, on the transcvr, switches from DIG to USB. Also, the VAC is turned off, as well, at the same moment which, of course, cuts off my outgoing signal. I have tried using v1.8 but no change in the problem. I have tried rebuilding the database of OPENHPSdr v3.4.9 also with no success. I do not have this issue with FLDIGI or other third party software applications with the 10E.
Anyone experience something like this? Have I gone through all the troubleshooting steps to correct this?
WA2DIY
Re: WSJT-x and ANAN10E
In PowerSDR CAT setup enable "DigL/U Returns LSB/USB"
And in WSJT-x under Radio setup enable "USB" instead of "Data/Pkt"
de Mike W9MDB
mark1161
Post by mark1161 »
Mike,
Thanks, problem solved! I do operate the 10E on its own dedicated computer and mostly take it portable either in the field or at my club shack. I am looking at the other computer, for the 100D, and I don't have the "DigL/U Returns LSB/USB" selected and, yet, that rig performs nominally with WSJT-x. I am not a programmer so I will leave that anomaly to them. The setting for WSJT-x was always USB on both computers.
Thanks again
Mark WA2DIY
