Wave Record and Play
W6LVP
Post by W6LVP »
Sometimes it is nice to be able to record a receive audio snippet and then play it back so another op can hear how they sound. I am new to this radio and software so I am sure the answer to my question is simple. Using the REC and PLAY buttons in the upper left block, I can record audio and the play it back during receive. When I key the transmitter, I don't get any modulation.
Larry
W6LVP
W6LVP
Re: Wave Record and Play
Post by W6LVP »
I know it's not good form to reply to your own post but I figured out the solution to my earlier question.
I use two antennas connected to both receivers for diversity. I listen to one antenna on the left and the other on the right. Transmit only uses left audio which was the side I was using for RX2.
Take a look at this topic, particularly the W1AEX post on 20 Dec:
https://apache-labs.com/community/viewt ... 620&p=4613
