Thetis with NEW 7000 MKII
N4QNT
Post by N4QNT »
Looking for some feedback.. Any info using the latest Thetis version with Pro2 1.6 and Pure Signal with Amplifier not working.. The radio was shipped with Pro1- 2.4 which works fine with mRX OPSDR 3.4.9 and Pure Signal with Coupler and Amp 1200 watts.. But a no goes with Pro2 and Thetis.. Was told by Apache to go back to Pro1 firmware... When I had my 200D and 7000DLE the latest Thetis and Pro2 worked very well.. I feel like I took 5 steps forward then wanted to upgrade to the latest 7K-MKII (no-pc) mostly because of the greater heat-sink dissipation and larger case but now took 10 steps back with software and firmware support. Did something change with the latest MKII Boards why Pro2 and Thetis do not play well now?
Re: Thetis with NEW 7000 MKII
This is not a Thetis issue. It is a firmware issue. The fact of the matter is that P2 firmware is still very beta. Results will even vary between different serial numbers of the same model radio.
I can only suggest patience and assure you that newer versions of P2 firmware, and Thetis, are coming.
