1.8 causes Thetis to close during a PTT
Posted: Tue Apr 16, 2019 12:00 pm
by NC3Z
OK, since updating from 1.7 to 1.8 yesterday, I have had Thetis (2.6.4) close on me when I hit the PTT. This has only happened twice so far. But it completely and immediately closes Thetis. To recover you simply restart Thetis. I am using a 7000DLE (not mark II).
Re: 1.8 causes Thetis to close during a PTT
Posted: Tue Apr 16, 2019 1:13 pm
by NJ2US
Thetis 2.6.4, FW 1.8, 7000DLE
Same report. Several seconds into a PTT (transmitting), Thetis closed.
Jeff NJ2US
Posted: Tue Apr 16, 2019 2:03 pm
by n1gp
I can't repeat this behavior with my 7000 (non MKII).
Any chance someone who is seeing this frequently can get a wireshark capture
on the UDP data going between the SDR and HOST (all ports)?
Tnx,
-Rick / N1GP
Posted: Tue Apr 16, 2019 2:24 pm
by NJ2US
Rick,
I was able to wireshark capture the application close. However, I am not sure I have wireshark configured properly, I simply selected the interface, then clicked capture, then saved the result. I will email it to you.
Jeff NJ2US
Posted: Tue Apr 16, 2019 2:32 pm
by ea3aqr
Same problem on Anan 7000 DLE.
Rolling back to V1.7
Posted: Tue Apr 16, 2019 2:56 pm
by NC3Z
At least others are seeing this, I thought I was holding it wrong!
It's not frequent, and I am assuming we would need wireshark running the whole time until a crash??
Posted: Tue Apr 16, 2019 3:17 pm
This is a well known problem associated with MAC-PHY timing.
The best way to get the necessary data is to cycle PTT a million times quickly until the problem occurs, then launch Wireshark and take a second or two of data. That data will confirm (or deny) this is the same problem that has been seen many times before.
Posted: Tue Apr 16, 2019 4:49 pm
by NJ2US
The capture I sent Rick contains both the Pre and post closure data, he received the file and will analyze it later today. I’m sure he would welcome other captures in the mean time. I fell back to 1.7 to run a net for an hour, and had no problem.
Jeff NJ2US
Posted: Wed Apr 17, 2019 2:39 am
by n1gp
Tnx for the Wireshark capture Jeff. It gives me some valuable clues.
Also tnx for the testing of various images for a potential fix.
If anyone else would like to try this image (so far working for Jeff) for the Orion MkII Protocol 2 here's a link:
https://www.dropbox.com/s/00m5b649t5cww ... 2.rbf?dl=0
Appreciate any/all feedback.
-Rick / N1GP
