Thetis 2.6.6 released
Posted: Sun Apr 21, 2019 7:40 pm
https://github.com/TAPR/OpenHPSDR-Thetis/releases
This is a small maintenance release to fix the following bugs:
- Displaying EU region numbers
- Out of band errors on startup
- Transmit filter not displaying in split mode
Re: Thetis 2.6.6 released
Posted: Mon Apr 22, 2019 9:34 am
by DL8LAQ
I tried split in CW and SSB. In CW the VFO B carrier freq will be displayed in yellow and the RX filter if MultiRX is enabled. That is fine.
But in SSB I can't see VFO B on the panafall without enabling MultiRX!
Posted: Mon Apr 22, 2019 11:16 am
Try enabling TX FL.
Posted: Tue Apr 23, 2019 3:19 pm
by Tony EI7BMB
Edit : Apologies this was already covered in Scotts installation notes. RTFM for me
Posted: Tue Apr 23, 2019 5:33 pm
by ea3aqr
Check in the left side under "profiles" (setup/transmit)
Posted: Wed Apr 24, 2019 2:41 am
by FM5GB
Thank you Doug !
You did a great job
I installed V2.6.6.0 and switched back the Win7 region setting to France.
No trouble now : Thetis launches flawlessly.
When I had region UK selected I lost my HamRadioDeluxe Logbook (old free version 5.0)
and it did'nt come back after resetting France as region. I did not investigate why but purchased
the latest HRD version and now I am a happy camper.
Best 73s Phil FM5GB
Posted: Thu Apr 25, 2019 10:58 am
by DL8LAQ
w-u-2-o wrote:Try enabling TX FL.
That did not do the job. I started again with a reset db. Now I have the two yellow vertical lines show the ssb tx filter.
