Thetis 2.6.6 released
This is a small maintenance release to fix the following bugs:
- Displaying EU region numbers
- Out of band errors on startup
- Transmit filter not displaying in split mode
DL8LAQ
Re: Thetis 2.6.6 released
Post by DL8LAQ »
w-u-2-o wrote:https://github.com/TAPR/OpenHPSDR-Thetis/releases
I tried split in CW and SSB. In CW the VFO B carrier freq will be displayed in yellow and the RX filter if MultiRX is enabled. That is fine.
But in SSB I can't see VFO B on the panafall without enabling MultiRX!
Try enabling TX FL.
Edit : Apologies this was already covered in Scotts installation notes. RTFM for me :-)
ea3aqr
Post by ea3aqr »
Check in the left side under "profiles" (setup/transmit)
FM5GB
Post by FM5GB »
Thank you Doug !
You did a great job
I installed V2.6.6.0 and switched back the Win7 region setting to France.
No trouble now : Thetis launches flawlessly.
When I had region UK selected I lost my HamRadioDeluxe Logbook (old free version 5.0)
and it did'nt come back after resetting France as region. I did not investigate why but purchased
the latest HRD version and now I am a happy camper.
Best 73s Phil FM5GB
DL8LAQ
Post by DL8LAQ »
w-u-2-o wrote:Try enabling TX FL.
That did not do the job. I started again with a reset db. Now I have the two yellow vertical lines show the ssb tx filter.
