https://github.com/TAPR/OpenHPSDR-Thetis/releases
This is a small maintenance release to fix the following bugs:
- Displaying EU region numbers
- Out of band errors on startup
- Transmit filter not displaying in split mode
Thetis 2.6.6 released
Re: Thetis 2.6.6 released
I tried split in CW and SSB. In CW the VFO B carrier freq will be displayed in yellow and the RX filter if MultiRX is enabled. That is fine.w-u-2-o wrote:https://github.com/TAPR/OpenHPSDR-Thetis/releases
But in SSB I can't see VFO B on the panafall without enabling MultiRX!
Try enabling TX FL.
Edit : Apologies this was already covered in Scotts installation notes. RTFM for me
Check in the left side under "profiles" (setup/transmit)
Thank you Doug !
You did a great job
I installed V2.6.6.0 and switched back the Win7 region setting to France.
No trouble now : Thetis launches flawlessly.
When I had region UK selected I lost my HamRadioDeluxe Logbook (old free version 5.0)
and it did'nt come back after resetting France as region. I did not investigate why but purchased
the latest HRD version and now I am a happy camper.
Best 73s Phil FM5GB
You did a great job
Best 73s Phil FM5GB
That did not do the job. I started again with a reset db. Now I have the two yellow vertical lines show the ssb tx filter.w-u-2-o wrote:Try enabling TX FL.
