Tried Thetis again, now VAC is broken.
I have, from time to time, tried Thetis on my 200D and always with the same results. It doesn't work with VAC2. Up to now, I've been able to roll back to Protocol 1 with the bootloader and go back to 3.4.9. This time, however, PowerSDR will not work with VAC2, giving a port error (see attachment). I have: reinstalled PowerSDR, reset the database, uninstalled and reinstalled various virtual audio channels (Banana, Potato, VB-A, and MVAC 4.15). Any ideas, anyone?
- port error.PNG (98.52 KiB) Viewed 8153 times
Re: Tried Thetis again, now VAC is broken.
You will probably have to reset your database.
Reset the database, when that didn't work removed all components and folders and did clean install including wisdom. Audio works when routed through UMC ASIO on either VAC channel 1 or 2, but crashes when MME, Windows Direct, or WDM-KS is used to route sound through any device, including built-in sound card or UMC.
Buck ko0y
Buck ko0y
OK, fixed. Somehow, in all the un/reinstalling and rebooting, the microphone got turned off in privacy settings. Sigh.
Buck ko0y
Buck ko0y
Good find! This thread is bound to help somebody down the road...
