Anan-10 power meter suddenly off
WB4AIO Kevin
Post by WB4AIO Kevin »
My Anan-10's displayed forward power reading (OpenHPSDR mRX 3.4.9) is suddenly off.
Instead of reading 8 Watts forward when in tune mode as it normally does, it now reads 18 to 25 Watts depending on the band.
The readings on my Telepost LP-500 external power meter haven't changed; it shows 8 Watts like always.
Another odd thing -- if I reduce the Drive setting to zero, with confirmed zero output using my external wattmeter, the rig's forward power reading now shows 5 Watts.
A database reset had no effect on this problem.
Any ideas?
Kevin.
Better fidelity means better communications.
Re: Anan-10 power meter suddenly off
It is suggestive of a hardware failure.
