Installing Protocol-2 on my 100D FAIL!!!
OZ1CT-Ben
Post by OZ1CT-Ben »
Hi all
I try to install Angelia_Protocol_2_v12.0 and also try Angelia_Protocol_2_v11.8 but my Anan-100d do not start up ??? why ??
if I do a IP-scanning I can't find the IP off the ANAN-100D so it looks as it do not get any IP adress ???
I use PC + ANAN-100D + Switch(go to my router) but do I need a seperat ethernet card to the ANAN-100D ???
I then flash back to Angelia_v6.0 and then it startup whit HPSDR 3.4.8 whit no problem ...
73" OZ1CT Ben
OZ1CT-Ben
Re: Installing Protocol-2 on my 100D FAIL!!!
Post by OZ1CT-Ben »
Hi all
I have now install a new Gigabit ethernet card in to my computer and connected a cable directly to the ANAN-100D and
now my ANAN-100D startup.... :D :D :D so now I can start testing Thetis :D :D :D
73" OZ1CT Ben
SA3ATF
Post by SA3ATF »
Good news Ben!
Hope you find it as interesting and good as the rest of us :)
I saw your post earlier this morning on my phone but hate typing on that thing. I was going to ask you about your network card and switch. Now that I am at a computer I see you have solved the problem.
Yes, P2 requires Gigabit Ethernet. It will not run at any other speed. It will not auto-negotiate speeds. This is a limitation of the firmware design in order to keep it simple and small enough to fit into the smaller FPGAs.
If you buy a Gigabit Ethernet switch, you can go back to using your switch as well.
