Database not saving TX EQ Enabled and Phase Rotator Endable options
KW4CQ_Bob
Post by KW4CQ_Bob »
After clicking on the Transmit Equalizer (enable) and the Phase Rotator (enable) and then on Apply and then saving the changes to a new database by clicking on OK, when I Import that same database all saved settings I made are there except that the two enabled options I just described are not saved. They are unchecked. I have to re-enable those two every time. Any thoughts on this?
Bob KW4CQ
Re: Database not saving TX EQ Enabled and Phase Rotator Endable options
Try saving as a transmit profile Bob if you have not done so already.
KW4CQ_Bob
Post by KW4CQ_Bob »
Thanks Tony. That works.
73 Bob
