VAC keeps turning off
w8du
Post by w8du »
Mates:
I know I asked this before, but I cannot locate the answer given so I apologize for repeating the question:
I am running Thetis 2.6.8 on a 7000DLE MkII. Lately, I have noticed that VAC ON does not persist when I close and then later re-open Thetis.
How do I get the state of VAC to persist?
Tnx de Arnie W8DU
Re: VAC keeps turning off
save the tx profile
Hi Arnie
Just to elaborate. Certain settings are assigned/saved along with the TX profile. A tx profile is applied when you restart and if the settings have not been stored 'into' that tx profile then things like this will happen. There are settings available to save TX profile on shutdown to overcome this if that is what you want to do.
w8du
Post by w8du »
Thanks Richie. I was fooled by the "TX Profile" part of it because I did not think of it as part of the TX profile. I stand correct and thank you for the reply. That did solve the problem.
73 de Arnie W8DU
