RX'er 2 glitch on 2.6.8 and .9
GW0DQW
Post by GW0DQW »
Hello every one ,
I have a peculiar issue that when i select to use my 2nd receiver the windows comes up alright , but the default freq i have set ( 882Khz) is in the setting box but the second receive windows comes up with strange frequencies every time .
I have tried to sort but have failed , any one else had this issue or can give me some assistance please.
Regards
Chris
GW0DQW
Re: RX'er 2 glitch on 2.6.8 and .9
Seems like a bug, Chris. We'll have to wait for Richie or someone to fix it.
W4WMT
Post by W4WMT »
Unable to reproduce that here, works FB with RX2 set to 882 kHz.
Are you sure it's not a database corruption issue?
GW0DQW
Post by GW0DQW »
Bryan W4WMT wrote:Unable to reproduce that here, works FB with RX2 set to 882 kHz.
Will try that Bryan , thanks for your help , need to look up how to that as never done it .
Thank you .
GW0DQW
Post by GW0DQW »
Thank you .
Have now reset my database and mostly is OK , like I am not getting freq corruption when bring up RX 2 , Pure Signal is working OK , The only thing i need to sort out now is the PTT is not working off the space bar.
Thank you Bryan and Scott and others for your input .
Best wishes from Wales
Chris GW0DQW
DL8LAQ
Post by DL8LAQ »
GW0DQW wrote: ...
Hi Chris,
try this: https://apache-labs.com/community/viewt ... 303#p10111
