RX'er 2 glitch on 2.6.8 and .9
Posted: Wed Feb 12, 2020 9:14 pm
by GW0DQW
Hello every one ,
I have a peculiar issue that when i select to use my 2nd receiver the windows comes up alright , but the default freq i have set ( 882Khz) is in the setting box but the second receive windows comes up with strange frequencies every time .
I have tried to sort but have failed , any one else had this issue or can give me some assistance please.
Regards
Chris
GW0DQW
Re: RX'er 2 glitch on 2.6.8 and .9
Posted: Wed Feb 12, 2020 10:17 pm
Seems like a bug, Chris. We'll have to wait for Richie or someone to fix it.
Posted: Thu Feb 13, 2020 10:24 am
by W4WMT
Unable to reproduce that here, works FB with RX2 set to 882 kHz.
Are you sure it's not a database corruption issue?
Posted: Thu Feb 13, 2020 10:52 am
by GW0DQW
Bryan W4WMT wrote:Unable to reproduce that here, works FB with RX2 set to 882 kHz.
Will try that Bryan , thanks for your help , need to look up how to that as never done it .
Thank you .
Posted: Fri Feb 14, 2020 8:24 pm
by GW0DQW
Thank you .
Have now reset my database and mostly is OK , like I am not getting freq corruption when bring up RX 2 , Pure Signal is working OK , The only thing i need to sort out now is the PTT is not working off the space bar.
Thank you Bryan and Scott and others for your input .
Best wishes from Wales
Chris GW0DQW
Posted: Fri Feb 14, 2020 8:43 pm
by DL8LAQ
GW0DQW wrote: ...
Hi Chris,
try this: https://apache-labs.com/community/viewt ... 303#p10111
