Things to check post Windows Update...
Post by K9RX »
I've named this topic - now just need to know what to fill in for it.
I've had very good success with Eugene's VAC and FT8/MSK144 for a long time now - I've never had an issue where a Windows update seemed to bother anything. But I had an update 2 days ago (i believe it was) and now I have audio click and pop issues. I look at the AUDIO tab and the OOPS is updating routinely ... pop...... click, click .... pop ... every 1 - 10 seconds or so. The counter went from 0 to 24 in under a minute. Previous to this last update I was having very few of these.
where might someone go to to check - something Windows might have changed (in their infinite wisdom) that could impact this? please.
Re: Things to check post Windows Update...
Windows updates are famous for damaging audio drivers. More than once I've had to uninstall-reboot-reinstall-reboot-reconfigure Voicemeeter.
Check the sample rates of your devices in the Windows sound control panel. Consider reinstalling any audio devices or drivers.
Post by K9RX »
Thanks Scott... well this is what happened post my note - it might be germane to someone seeing/using this thread.
-this morning, with everything powered up 24/7 as usual, I tried to work someone on 60 FT8 - no transmit signal. It went to TX but nothing showed on the TX pan. Tried this and that - reset the TX Profile (there's a bug in there that still persists re split mode) ... still nothing. In frustration because the spot was for someone I needed on 60M for a new one I restarted the program - nothing. Restarted WSJT-X, nothing, tried running JTDX - same thing. In the latter 2 cases I had the service panel for EUG M VAC program up and it clearly showed audio there on TX.
-rebooted the computer - now when I tried to run PSDR the initial panel with the bar would go about 30% and just disappear. Nothing.
-went in and renamed database to database-x and ran PSDR - completed this time. Imported the 2nd to last database. All has been fine since then...
-and now no more OOPS going on, no more than normal! In 5 minutes of operation zero OOPS - yesterday it would have been hundreds...
