Wave Recording NO PTT
G3NPI
Post by G3NPI »
I am trying to use the v3.4.9 Wave feature as an auto cq sender. The recording is OK, but the PTT is not switched when clicking play. I can make it sort of work using VOX but this is not very stable.
Is there a way of switching on the PTT direct from the PLAY button in Wave?
TIA
Geoff G3NPI
Re: Wave Recording NO PTT
I do not believe there is any way to do this. To playback a recording MOX must be activated first. If you are using VAC, the MOX override option must be enabled in VAC setup.
G3NPI
Post by G3NPI »
Thank you Scott. Looks like I will have to go back to N1MM and battle with the VAC interface....
Geoff G3NPI
