Main Filter attenuating signals on 20M and up
VK3ICM
Post by VK3ICM »
Hi -
I've had a 7000DLE MkII for two days now, so I'll preface this by saying it's probably something obvious. I'm running Protocol 2 (v. 2.0 firmware) and Thetis works great.
I'm seeing something in SDR Console (3.0.20) I can't explain. Could anyone verify this on their setup?
On 20M and up, if I turn 'Main Filter' on, it attenuates a test signal anywhere from 10-20db. On 40M and below it does not. It seems like the wrong filter is being switched in - I've not been able to replicate this in Thetis.
Cheers - Chris
Simon
Re: Main Filter attenuating signals on 20M and up
Post by Simon »
Hi Chris,
Must be a bug - notes, with luck I'll look at this next week. Best place for support is https://www.sdr-radio.com/support as that's monitored all the time (well, inbetween beers).
sdr-radio.com
PD3LK
Post by PD3LK »
Hi Cris, i can't reproduce this on 20m with my 7k. (RX and also protocol 2 v. 2.0)
Where's the test signal coming from, another TX nearby or a LOW power hf generator?
Do you see the attenuation also without that test signal ...10-20db noise drop?
Return to “SDR Console”
