No audio in SAM or AM mode
rbduck
Post by rbduck »
I'm running Thetis v2.7.0 (3/1/20) MW0LGE (a3). I'm getting no audio when I switch to either the SAM or AM modes. No sound of any kind. I've check audio settings, Sample Rate, Buffer size and timings. All other modes work perfectly. I have not tried reloading the firmware yet. It was working a few days ago. I really have not changed anything that I can remember. Squelch is off. I tried maximum AGC. I can listen in DSB, but it just doesn't sound right. Maybe there is something I'm missing . I will appreciate any help you can provide. Thank you!
Re: No audio in SAM or AM mode
Sounds like you may need to reset your database. Save/export the old one in case you want to go back, reset it, and see if that fixes the problem. Because there really isn't any setting that would cause AM and SAM to stop working while the other modes continue to work.
rbduck
Post by rbduck »
I suspected as much. I'll reset the database and see how that works. I'll report back what my findings are. I'll be back.
Thanks Scott!
rbduck
Post by rbduck »
Yes Scott, Reset the database and that did the trick. The rest of my settings I can quickly recover. I just about have them all memorized. For the rest I have screen captures. Thanks again.
