Keyboard commands in Thetis
I have an Anan 7000DLE ii. I have just upgraded the firmware to protocol 2 v2.0b and am now using Thetis 2.6.9. When I had the original PowerSDR software I could use keyboard controls such as space bar for PTT. In Thesis none of that works any more. I can go to transmit with the MOX button but not with the sapce bar. My PC keyboard works perfectly in all other applications on my PC. Is there some sort of global on off for keyboard commands in Thesis that I am missing or does anyone have any idea what the problem could be with no keyboard commands working.
Re: Keyboard commands in Thetis
Go to setup/general/options and check "enable shortcuts" on keyboard options
Brilliant! thank you I knew it would be something easy. That worked straight away.
Terry.
Terry.
Where can I find a listing of keyboard shortcuts implemented in Thetis?
Tnx de Arnie W8DU
Tnx de Arnie W8DU
You can get a list of the current shortcut keys in the Thetis manual. It can be downloaded here http://www.nicklebyhouse.co.uk/index.ph ... -draft-0-4.
I hope this helps.
I hope this helps.
Thanks Ruben! That helps.
73 de Arnie W8DU
73 de Arnie W8DU
