RX1 AF: CAT command????
Posted: Fri Jul 17, 2020 4:36 pm
by OZ1CT-Ben
HI All
Just started to modify my own " basic_controller" made by John Melton g0orx/n6lyt but I need the CAT command for the RX2 AF: ??
...I know that "ZZAG" is master AF
73" OZ1CT Ben
Re: RX1 AF: CAT command????
Posted: Fri Jul 17, 2020 6:12 pm
See this topic:
https://apache-labs.com/community/viewt ... 577&p=3827
The CATStructs.xml file appears in the similar directory under Thetis as well, if you are using Thetis.
Posted: Fri Jul 17, 2020 6:51 pm
by OZ1CT-Ben
Hi Scott
Yes I did see in the CATStructs.xml file in Thetis directory..... but there is nothing ....
so I still look for RX1 AF: but maybe there is no cat command ???
73" Ben
Posted: Fri Jul 17, 2020 7:50 pm
There are CAT commands for all audio levels. The problem is that they are poorly labeled/poorly named. I had to go into both the XML file and the Flex reference document and look through them for you.
In CATStructs.xml:
Master AF is called "extended AG Gain", ZZAG
RX1 AF is called "RX0 Gain", ZZLA
RX2 AF is called "RX2 audio level", ZZLE
There is also "RX1 Gain", ZZLC, which I think is for the main (RX1) sub-receiver.
You will have to test all of these to see what they really do. You can do this in Thetis by going to Setup > CAT Control > CAT > Test CAT Commands.
Posted: Sat Jul 18, 2020 11:57 am
by laurencebarker
There is a CAT command reference guide in the Thetis documentation.
https://github.com/TAPR/OpenHPSDR-Theti ... tion/Radio
It isn't absolutely up to date but you are unlikely to encounter the newest CAT commands yet, I will ask Doug to add the newest one at a convenient point.
Posted: Sat Jul 18, 2020 2:41 pm
by OZ1CT-Ben
Hi All
Just what I need for my Cat-controller.... I am runnig it on a small Arduino Micro board....
hare is a picture where the SKF-ball bering encoder and enclosure will be put together
