Anyone see "ADC1 Overload" on TX?
Posted: Wed Jul 22, 2020 4:25 pm
by AB5N
Hi guys-
Does anyone else get a "ADC1 Overload" warning during digital transmission? I'm running Protocol 2 with a DLEII.
Running VoiceMeeter to route TX monitor audio to speakers. ALC is -2. Signal is clean. Only if I reduce VAC 1 TX Gain
to where it is about 10 W output- does the warning go away. I'm baffled. Just checked and it goes away if I close VoiceMeeter.
Thanks- Bob-AB5N
Re: Anyone see "ADC1 Overload" on TX?
Posted: Wed Jul 22, 2020 7:10 pm
Did it just start doing this, or has it always done it?
Are you running PureSignal?
What is your receive attenuator setting going to during TX?
Posted: Fri Jul 31, 2020 5:20 pm
by AB5N
It never occurred again! IF it does... I'll collect data. Tnx Bob
Posted: Thu Oct 14, 2021 8:54 pm
by JJ4SDR
AB5N wrote:Hi guys-
Thanks- Bob-AB5N
I saw ADC1 overload only today. Running Thetis 2.8.11 (10/20/209) /P1 with my Anan 7000 DLE MKII. Haven't changed any parameter settings for weeks and I am seeing the "ADC1 overload" in yellow color while monitoring 20 meters, not transmitting at all. I did use the SPLIT feature to work S9OK on 20 m SSB for a while. Only after using the SPLIT feature did I start seeing this overload message.
Puzzled!
