Anyone see "ADC1 Overload" on TX?
AB5N
Post by AB5N »
Hi guys-
Does anyone else get a "ADC1 Overload" warning during digital transmission? I'm running Protocol 2 with a DLEII.
Running VoiceMeeter to route TX monitor audio to speakers. ALC is -2. Signal is clean. Only if I reduce VAC 1 TX Gain
to where it is about 10 W output- does the warning go away. I'm baffled. Just checked and it goes away if I close VoiceMeeter.
Thanks- Bob-AB5N
Re: Anyone see "ADC1 Overload" on TX?
Did it just start doing this, or has it always done it?
Are you running PureSignal?
What is your receive attenuator setting going to during TX?
AB5N
Post by AB5N »
It never occurred again! IF it does... I'll collect data. Tnx Bob
JJ4SDR
Post by JJ4SDR »
AB5N wrote:Hi guys-
Thanks- Bob-AB5N
I saw ADC1 overload only today. Running Thetis 2.8.11 (10/20/209) /P1 with my Anan 7000 DLE MKII. Haven't changed any parameter settings for weeks and I am seeing the "ADC1 overload" in yellow color while monitoring 20 meters, not transmitting at all. I did use the SPLIT feature to work S9OK on 20 m SSB for a while. Only after using the SPLIT feature did I start seeing this overload message.
Puzzled!
